Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-22-2009, 05:45 PM
racerx6466 racerx6466 is offline
racerx6466 is starting off with a positive reputation.
Trans Slip
Have a 99 F-150 2wd with a 4.6. Recently (less than 1000 miles ) ago had trans rebuilt. Put it back in and the trans slips going into overdrive. When it goes to shift the motor will rev up before it engages but after that it will engage solid and not slip anymore. It's not so much a slip but more like putting it in neutral, revving the motor, then putting it in drive. And only going to overdrive. Also trans was done for free (by a reputable shop) but free with no warranty and yes the fluid is full. Any help is appreciated
__________________
-2002 Ford Excursion Limited V-10 4x4 -Lifted with Bilstein 5100's and BFG All Terrains
-1999 Ford F-150 XLT 4.6 2WD -Hyperteched with K&N and Flowmaster exhaust -JBA Shorty Stainless Headers
-4.56's with Eaton Locker and Superior Axles
-Camburg Front Suspension -Deaver Leaf springs in the rear -Bilstein 5100's
  #2 (permalink)
Old 02-22-2009, 06:13 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Sounds like Torque converter...did they replace it when they did the rebuild?
  #3 (permalink)
Old 02-23-2009, 07:44 AM
DarrinBC DarrinBC is offline
DarrinBC is starting off with a positive reputation.
To me it sounds like a valve in the valve body is sticking or an overdrive servo issue.
Darrin
  #4 (permalink)
Old 02-23-2009, 02:31 PM
Yeah in fact that is why I had the trans rebuilt. There was nothing wrong with the trans at all but my converter locked up and wouldn't slip. Figured with the converter failure and having the trans out I might as well rebuild since it had 175,000(probably more from gears and tires before the calibration) on it. Darrin is the servo something that can be fixed without dismantling or pulling the trans?
__________________
  #5 (permalink)
Old 02-24-2009, 09:19 AM
You don't have to remove the transmission, but you do have to remove the valve body and it's kind of tricky to remove and re-install the OD servo.
I can talk you through that if you need me to. As a matter of fact I might take some pictures and create a little article for that.
There is an issue with these transmissions with leakage around the 'pin' on the overdrive servo. I am working on coming up with a better solution than the Sonnax kit for that. Their kit works, but you have to do some work to the case to install it. A lot of guys mess it up and end up cutting the o-ring when they install the new pin.
I don't think it's the torque converter. But, you can test the converter in 3rd gear by using your OD lockout switch and turning off OD. If the converter locks and unlocks properly in 3rd gear then that isn't it.
Darrin
  #6 (permalink)
Old 02-24-2009, 12:57 PM
That would be great, I need all the help I can get. I'll probably drain the fluid tomorrow and check it out. Where would I be able to buy the servo
__________________
  #7 (permalink)
Old 02-24-2009, 01:02 PM
Or would this be what I need AODE 4R70W transmission servo piston,AODE 4R70W transmission parts
__________________
  #8 (permalink)
Old 02-25-2009, 08:01 AM
That's the correct replacement.
You have to take the valve body down to get to it and you are going to need something to compress it into the bore so that you can remove the snap ring to get it out.
On installing it you are going to need to use a long thin screwdriver to manipulate the band through a hole in the case under the valvebody to make sure it engages the servo or it won't work when you put it back together. This is easy to do, but VERY easy to mess up when you are not used to doing it.
Again, when I get time I will try and do something for some sort of article on a 'how-to'
Darrin
Tags
4r70w , location , overdrive , remove , servo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
