Filling Rust Holes - crazy question - Ford Truck Enthusiasts Forums
Old 02-22-2009, 04:19 PM
Skydmark1 Skydmark1 is offline
Skydmark1 is starting off with a positive reputation.
Hey guys, I just bought a 1995 F150 Ex. Cab 4X4 XLT. I paid $800 for it, mechanically it's in good shape but the body has seen better days for sure. I'm going to need to get this inspected as soon as I get it and I have no garage right now to do the body work (still winter here) SOOOOO here's what I was thinking, maybe I can use something to fill the holes for now and when it gets warm I can do the body work properly. For example, how do you think Gap filling spray foam would work? I've seen people duct tape over holes and some mechanics will pass it, but that's a bit too ghetto for me.
Let me know your ideas!!
Thanks,
~Jason
Old 02-22-2009, 06:04 PM
kenseth17 kenseth17 is offline
kenseth17 is gaining momentum as a positive member of FTE.
A used car dealer around here was rumored to use spray foam to plug holes and mud over them. I wouldn't expect it to be a long term repair and it sure isn't the right way to do it.
I think spray foam would be a ghetto move as well, and I've never used the stuff for a shoddy repair, but do know that stuff supposedly expands alot. So you may have to be carefull spraying it in an enclosed area, or you could maybe end up buckling something.
Then there is the whole fact that its flammable so if you do later go the right route and replace metal, and you weld, you probably should dig all that stuff back out, so you don't risk starting your truck on fire.
I'd almost think more of the macco route, stuffing with newspaper, and duct tapeing and filling over would be better if just trying to pass inspection. Then you only have wasted the price of some plastic filler and spray bomb to cover, and be probably easier to remove when you get time to do it right. Heck, maybe a good pothole will do the job of removeing it for you.
Good thing they don't have inspections around here, being this is the rust belt and have a lot of rust lightened vehicles running around.
Old 02-22-2009, 08:19 PM
I would fill it and mud over but, I'd have to work outside in cold conditions.... 30 degrees or less. Do you think the bondo will harden and stick properly?
Old 02-22-2009, 09:07 PM
Chaosracing's Avatar
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.Chaosracing is gaining momentum as a positive member of FTE.
I would say yes you can use the foam to fill it in. I got plenty of junkers that were fixed that way. My mom (then brother) had an 84 Cougar where the trunk rotted in the spare tire well. My guy that does my inspections told me to just bondo over it. Once I removed the carpet, the hole was worse than we though, so I used window screen and bondo to cover it (it was supposed to be temp, but never got around to fixing it) That lasted for a couple of years. The last year it was on the road I used a whole tube of caulk to repatch the trunk area. Here in PA, as long as the holes are covers, they dont care. My father in law uses that Alum duct tape and then sprays primer on it. He has a 80's Bronco that has the all to familiar rot in the quarters.
Old 02-22-2009, 09:13 PM
Well normally you want to apply plastic filler over warm metal and temps, but seeing as this is only temp, and considering your stuffing a hole with the stuff anyways. Use a good amount of catalyst in the bondo, and you can help cure it with a heat gun, heat lamp, or even possibly a hair dryer. Also could use them to warm metal before applying it.
The actual air temp isn't as important as having metal warm and keeping the metal warm to help the filler kick.
Old 02-22-2009, 09:36 PM
thanks guys, I think I know what I'm going to do for now....once it warms up outside I'll spend some time cutting the metal out and doing it right.
Old 02-23-2009, 07:49 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
No spray foam. Filler will have a hard time setting up in the cold. For a temp fix, fiberglass and resin. It generates it's own heat to cure mixed to directions. But definatly a short term fix only.
Old 02-23-2009, 06:54 PM
hacking_in2002's Avatar
hacking_in2002 hacking_in2002 is offline
hacking_in2002 is starting off with a positive reputation.
I'd stay away from the foam method, I've seen a lot of pickup cab corners "repaired" temporarily like this........Most of the time the stuff's like a wet sponge, and causes more rust than you started with.....
Old 02-24-2009, 06:35 AM
gfw1985's Avatar
Cranky Old Guy
Just when I thought I had seen everything. Harbor Freight Tools - Quality Tools at the Lowest Prices
Transfer Case Overfilled?? Jason T 1997-2006 Expedition & Navigator 7 01-06-2015 02:04 PM
TOOL FORUM noplugs4me Site Announcements 2 03-12-2014 07:47 PM
Front brake dust covers Skydmark1 1987 - 1996 F150 & Larger F-Series Trucks 9 10-17-2010 08:55 PM
1977 - 1979 F150, and F250 bodies jason10henry 1973 - 1979 F-100 & Larger F-Series Trucks 11 11-10-2008 12:04 PM
Requesting Pics of Amp Install Behind Rear Seat jmaday Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 22 11-10-2007 10:43 AM
Tags
cold, fill, fix, fixing, foam, foaming, hole, holes, inspection, pass, rust, spary, spray, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
