Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
New Taurus X Hood
Old 03-04-2009, 09:42 AM
caprang's Avatar
caprang
caprang is offline
New Taurus X Hood
I just thought I would share some info....you may want to check your hood. A basketball pole blew over on my wife's X and dented the hood. Took it to a body shop to see what could be done. He did a parts locater and did not find any used hoods and there are also no aftermarket hoods available. The only option was to fix this one or get a whole new one.
So looking at the hood closely I found paint bubbling along the seam at the very front. Popped the hood to look underneath and it was even worse. Body shop tells me its an aluminum hood and where they weld the seam sometimes all the gas from the welder doesnt get wiped off and then the paint doesnt stick real well. I dont now how I never noticed this before!!
Anyway, total cost for new hood, painted and installed came to $1,357
Im going to take a magnet to the hood to see if it is really aluminum or not because the estimate has a charge for corrosion protection. If its aluminum it cant rust so why would it need corrosion protection? Not that it matters, Im just curious now.
Old 03-04-2009, 07:58 PM
juneau76's Avatar
juneau76
juneau76 is offline
Aluminum does corode/oxidize. One of our fire trucks would be a perfect example of that. The metal is corroding causing bubbles underneath the paint, etc. At any rate, that sucks. What year is your Taurus X?
Old 03-04-2009, 09:59 PM
caprang's Avatar
caprang
caprang is offline
It is a 2008 Limited that we bought September of 2007. I did the magnet test and sure enough it is an aluminum hood. Fenders are steel though.
AXracer
26
07-29-2023 10:54 PM
reamer
2004 - 2008 F150
04-14-2011 09:35 AM
ShouldaBoughtAToyota
07-23-2010 06:38 AM
rangersvt04
04-22-2010 10:35 AM
77camperspecial
12-30-2006 11:12 AM
Quick Reply: New Taurus X Hood
