Governor Adjustment - Ford Truck Enthusiasts Forums
Governor Adjustment
Old 02-21-2009, 04:14 PM
chubyboy's Avatar
chubyboy chubyboy is offline
chubyboy is starting off with a positive reputation.
Governor Adjustment
When i talked to the current owner about the truck im buying, he said the RPM governor cuts the engine at the beginning of the ellow area. My question is this. How would i go about adjusting the governor for the RPMs? I would like to get it to stop at or just below redline, not that i plan to be in the yellow that much anyways, but a from what i learned driving semi, having a couple hundred RPM reserve comes in real handy at times. And before anyone gets on me about diesels not being high RPM engines, i know that, i went to one of the best truck driving schools in the country and have held my CDL class A for a little over a year. When i took the truck for a test drive i found 2k to be a comfortable shift point. Once i get used to the truck i will prolly shift around 1250-1500 though.
Old 02-21-2009, 04:34 PM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Only way to change it is the governor spring itself. If ur going to do that ull probaly turn up the pump. So go ahead and get u a pyrometer. Just as some insurance. These things can get hot real quick at that rpm.
Old 02-21-2009, 10:28 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I thought the governor was set at 3300rpm? So you should never have a problem correct?
Old 02-21-2009, 10:31 PM
dyoung14's Avatar
dyoung14 dyoung14 is offline
dyoung14 is starting off with a positive reputation.
goveners are all set different on every motor, ny dads will bounce all day long on 3800 rpm and it has tha stock factory injection pump
Old 02-22-2009, 09:35 AM
89ford73's Avatar
89ford73 89ford73 is offline
89ford73 is starting off with a positive reputation.
i had a 4k governor spring in my ol 7.3 in high school. go to an injection pump rebuild shop and see if you can get a 4k spring i dont know what they use these for, but it makes an idi so much more fun to drive. i used to shift at 3600
Old 02-22-2009, 03:20 PM
dyoung14's Avatar
lol yea i need a tach first
Old 02-22-2009, 11:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Most of them were around 35 or 3600 when they were new.
But like everything else, they get weaker with age.
In-depth DB2 question: Adjusting governor response Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 06-21-2014 02:06 AM
ford c4 governor spring bbf150 Clutch, Transmission, Differential, Axle & Transfer Case 17 06-15-2013 02:55 PM
C6 Transmission tail housing removal help DanCampbell Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 09-29-2010 09:19 AM
Can I adjust Max RPM? Jim McCarty 6.0L Power Stroke Diesel 20 01-08-2007 03:33 PM
Holley 885 Carb and Governor John - NNY 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 07-01-2006 08:11 AM
Tags
1990, 1994, 460, 73, adjust, adjustment, b600, change, diesel, f250, ford, governer, governor, idi, industrail, motor, spring, straight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
