Van Turbo High Flow Outlet Options?
on
are you meaning the EBPV delete??
after you take the stocker off the truck use a dermal and grind the 2 rivets off of the flapper and punch them out...the flapper should fall off at this time..on the actuator side..pull the little C clip out..take some vice grips and wiggle and twist the rod out..pick up a 3/4 inch freeze plug and smack it in with a hammer..
thank you,
diesel site has deleted outets..thay also have a what they call a high flow outlet..from what i under stand..its a waste of $$$
http://www.dieselsite.com/index.asp?...ROD&ProdID=862
thank you,
It's for the Van Turbo, Ron. The stock outlet is too small so a custom non-EBPV outlet is required anyway.
I'd hit Ron up offline, Clay. His direct phone number is in his store, but if you need it, let me know. He can make better deals one-on-one than through FleaBay...
BTW, it should be right around a C-note for that outlet, maybe less from Ron directly.
Call Ron! Here's what you need (minus the exhaust housing, obviously):
eBay Motors: 99 03 POWERSTROKE TURBOCHARGER PEDESTAL & TURBO FLANGE (item 310124487475 end time Feb-28-09 23:27:14 PST)
