toyota box questions
I suspect it may be you alignment, an inch at the wheel rim isn't very excessive. Try adding a caster shim (available from MF) betwee the axle and the spring on each side oriented so the top of the axle tilts back more and see if the wander (or tramlining as it's called when the wheels want to follow the cracks in the pavement) lessens. Also check the toe in, you want at least ~ 1/16" toe in. One last thought are you running bias ply or radial tires? Bias plys have a lot more tendency to wander.
I'd check with Sanderson (directly, they pretty much know what will fit what), a set of center outlet, block hugger shorty style or maybe up swept and extreme rear long tubes if you are going for the pro street look.
I agree with the axracer on the alignment issue. Caster comes into play more than people think. Try getting on a bicycle and turning the handle bars around and see how much steering comes into play. That is what caster will do. The caster shim usually has a center hole or a groove so it will fit with your center bolt. Good luck.
toyota box
Wow, those used boxes are hard to find. Tracked 4 of them on ebay in the last 3 weeks. $175 to $300. Has to be ford guys making the swap. Core charges are 125 to 200 depending on the vendor, so a used box with the pitman arm, nut and fittings may be worth that much, but not to me.
Axracer... you mentioned adjusting the play in "both" directions. I am only familiar with the one adjustment on the side.
can you explain?
thanks
can you explain?
thanks
can you explain?
thanks
can you explain?
thanks
touota power box conversion
thanks to all, and especially AXacer. Tried that site, found a box for under $100, with freight. Installed it and test drove it today. This is more like it. Typical trammelling, but I can control it. No more slop in the steering.
Now for a confession... My driver is an 06 Magnum, with a hemi.
We also have an XK8 convertible, a 41 Pontiac coupe and a 28 ford Hot
Rod. This pickup was intended to be a grunt to support all the beautiful cars.
Instead, it's the first one out. Even before I fixed the steering. I just WANT to drive it every day.
Thanks again for all the help on this and other issues. I love my truck.
toyota box
New radials and 1/8th toe in.
I agree, it probably needs more caster. I added 4 degree shims, but it has a little rake and only reads 3 on the machine. It's very drivable, but when one wheel dips in a low spot it wants to walk. Have you ever put a sway bar on one of these? And does it help?
#29
