Help with 460 cruise control in HR Motorhome - Ford Truck Enthusiasts Forums
Old 02-20-2009, 08:21 PM
potts63 potts63 is offline
potts63 is starting off with a positive reputation.
My cruise died suddenly. The dash on Holiday Rambler has no light showing it is on. Is there a site I can obtain a wiring diagram to trouble shoot. I pulled the dog house and looked for obvious,like the cable off the servo or mouse chewed wires. At the time the recall was done, Ford said the issue with the fire danger did not cause my problem. All controls of course are on steering wheel. I did not have the $ to have Ford look further.
Thanks, POTTS
Old 02-20-2009, 11:08 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
What year is the chassis?
Old 02-22-2009, 11:56 AM
Sorry,
It is a 1995 Holiday Rambler stock 460 with 19k miles.
Old 02-22-2009, 01:45 PM
Franklin2's Avatar
www.helminc.com sells the factory Ford diagrams. You can see if they have yours in stock. A common failure for the cruise control is the wiring and slip ring behind the steering wheel, since the controls are mounted on the wheel itself.
Also check fuse #F,10a in the engine compartment, and fuse #9, 15 amp in the underdash fuse box. And even though your brake switch may not fall under the recall, it still could go bad, so make sure you have continuity through the switch with no brake pedal pressure.
Old 02-23-2009, 11:52 AM
Thanks for your help. I did check all fuses and I will check the brake switch for continuity. Not sure if I want to pull the steering wheel. I imagine it takes special tools and skill! You are the second person that suspected the slip ring and contacts in steering wheel. I my mind that was less likely because of the low miles on the rig, but perhaps another downside of it sitting idle so much of it's life!
Thanks again Dave
POTTS
attaching a flatbed... mike potts Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 35 08-09-2009 05:08 PM
cab and chassis bed??? mike potts Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 08-02-2009 03:37 PM
09 F350 Mileage, purchase experience, etc. Brown Dog 6.4L Power Stroke Diesel 11 07-28-2009 06:02 PM
cab and chassis bed ??? mike potts 1987 - 1996 F150 & Larger F-Series Trucks 5 07-24-2009 04:47 AM
Which programmer? 2008 F150 pott_2 2004 - 2008 F150 7 01-08-2008 11:01 PM
Tags
460, control, cruise, ford, motorhome, problem, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
