trans shuttering
trans shuttering
ok i got a 93 bronco
5.0 stock
e4od trans
3.08 gears
33x12.50r15 all terrains
6" bds lift
134000 miles
The trans just started shuttering trans fluid looks ok not burnt it dont do it when its cold only after warm up i tried some lucas trans additive didnt help should i get it back flushed? or drop the pan drain the convertor and re fill with new fluid and filter?
5.0 stock
e4od trans
3.08 gears
6" bds lift
134000 miles
I did the later and glad I did. Messy job but worth it. The magnet had 2-3 tablespoons of metallic goo around it and I guessed the filter had goo in it too. Shift points and down shifts improved greatly as a result. Remember to get the old gasket out when you pull the filter if it is not on the filter neck.
Stock gearing for a 93 with a 302 (5.0) is 3.55 with 4.11's having been an option. And 33's with 3.08's????! OMG! Does the E4OD EVER get into overdrive? I mistakenly ran 33's with 3.55's in my 92 for a while... tranny spent more time hunting for the right gear than I spend hunting for Bronco answers!
