1988 Marquis steering box
A few weeks ago I started a "steering column" thread where I mentioned a previous owner of the truck I have installed a power steering box from an '88 Grand Marquis in the truck and I was trying to figure out the best way to utilize the stock steering column with the new box. As one of you FTErs mentioned, there is a reason not many people have tried this steering box and I wish I could undo what was done to the truck, but I digress.
Anyway, I think I've figured out a way to make it all work, follow along with the pictures and tell me what you think.
This is the stock floor plate with the column in the stock position.
[IMG][/IMG]
This picture shows the column going through the floor without the cover plate and connected to the steering box via one u-joint.
[IMG][/IMG]
This is the new floor plate I made. For all of you fabricators out there, sorry I'm not the best in the world but I'm trying to learn. Since I won't have a clutch the plate is one piece. The solid circle is where the column needs to be positioned to meet with the steering box and the dashed circle is the stock location of the column.
[IMG][/IMG]
The next couple of pictures are of the steering column going through the hole cut in the new floor cover plate. As you can see, the hole I cut is just a wee bit off. The plan is to use a piece of exhaust tubing (seen around the column) as the lower column support. It will eventually be welded to the floor plate.
[IMG][/IMG]
[IMG][/IMG]
This last picture shows how the column connects to the steering box. I obviously have some more fitment issues to address, but this gives you an idea of how I'm proceeding.
[IMG][/IMG]
So what do you all think? Will this work ok? Can you think of something I'm missing or should consider before I weld it all up?
thanks,
David
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
thanks,
David
looks good to me. One thing you might check on your box and I'm sure its been mentioned but make sure when you turn the shaft(wheel) to the left its going to actually turn the truck to the left, it seems like I tried to use a late 80s marquis/crown vic box and it would of been backwards, not sure its been at least 5 years ago. Of course it depends on how the rest of its oriented, but it would suck to do all that work and have to scrap it for something else.
