Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-19-2009, 08:21 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
Garage is empty, add now
CheaperJeeper is gaining momentum as a positive member of FTE.
Making bio out of partially hydrogenated oils
So what are the issues? Anything other than reduced yeild?
What are the tips/tricks to getting good bio with paritally hydrogenated oil?
More heat? More NaOH/KOH? More Methanol? Longer processing?
I have a chance to pick up about 50 gallons of free oil but 40 of it is "partially hydrogenated" according to the guy wanting to give it away.
So is it worth the effort to go get it, or not? Can good bio be made from this kind of stock without going to some kind of extreme measures?
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #2 (permalink)
Old 02-20-2009, 09:30 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
I use it all the time. I blend all my WVO sources together. I've never noticed any difference, other than the Hydrogenated oil is thicker at colder temps. No difference in the bio though.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 02-20-2009, 10:11 AM
Thanks Fab. Thats pretty close to the answer I got on one of the other boards I'm on. A guy there responded and said it raises the cloud point of the bio a little, but other than that, and the oil having to be heated to liquify before going into the processor, there's really no difference.
__________________
  #4 (permalink)
Old 02-23-2009, 09:39 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Do you understand the difference between saturated and unsaturated VO?
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #5 (permalink)
Old 02-23-2009, 08:57 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Phydeaux, good to see you on the forum again. Hope all is well.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #6 (permalink)
Old 02-24-2009, 08:04 AM
Phydeaux88's Avatar
Thanks Trent.
I am doing well so far.
__________________
  #7 (permalink)
Old 02-24-2009, 10:55 PM
Quote:
I've read a little, but don't recall the details. Seems like it was something to do with whether or not all the ends of the HC chains had as many H atoms as they could hold. If so they are "saturated" with hydrogen (a.k.a. hydrogenated)...
But my memory (or understaanding) may be totally wrong. Care to refresh my memory, oh chemist buddy 'o mine?
__________________
  #8 (permalink)
Old 02-25-2009, 09:04 AM
Phydeaux88's Avatar
In saturated hydrocarbons each carbon atom is bonded to 4 other atoms, usually 2 other carbons and 2 hydrogen unless they're carbons at the end of the chain then they are bonded to 1 carbon and 3 hydrogens. Each bond is made up of a pair of electrons which the two atoms share.
In an unsaturated hydrocarbon at least on pair of carbon atoms share a double bond (an extra pair of electrons involved). In that case the carbons involved will each give up one of the usual hydrogens. Double bonds are more unstable than single single bonds and are the sites at which oxidation and polymerization occur, thus they are undesirable to a certain extent; however, they also have some beneficial qualities in that they tend to lower the cloud point of BD. As you can see it is a mixed bag of benefits some good some bad.
Hydrogenation is the process by which unsaturated hydrocarbon molecules may be converted to saturated, or fully hydrogenated, molecules.
All in all there is no reason to not use saturated or hydrogenated VO to make BD. It will be less likely to deteriorate thus will have a longer storage life but it will have a higher cloud point and will need precautions in cold weather.
__________________
  #9 (permalink)
Old 02-25-2009, 10:25 PM
WOW! My memory is better than I thought! I pretty much had it right! I'm not much of a chemist - only took 2 semesters of it in college 10-12 years ago - plus I only read one article on hydrogenation and saturated vs unsaturated fats! HOORAY FOR ME! Maybe my memory isn't slippin' as bad as I sometimes feel like it is
Thanks for filling in some of the finer points and details Phy. I can always count on you to help bring chemistry back down to a level that us non-chemists can get our heads around.
__________________
Tags
biodiesel, hydrogenated, oil, partially
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
