FREE and LOW Cost mods for 99-03 Powerstroke - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-19-2009, 06:46 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
Thought maybe this may be a good time to bring this up again.
Probly the best bang for the buck mod is the Wix 6637 air filter. I removed the air box top and some minor modification to the lower box to fit the filter. You can go a little more than this and add some air movement stuff.
Then I would add a gauge set, I found a BD X-monitor 3 in 1 digital gauge pod with limit alarms, for $200 on ebay. Easy to install and will get your attention if you over boost, over pyro, or heat up your auto trans.
Next on my list would be a tuner, I prefer DP Tuner. This custom programmed chip is an awsome improvement to the Ford powerstroke engine. Having the air flow from the 6637 really makes this the engine go and can get you better mpg's (if you say out of the throttle). This would be a less than $500 mod, depending on the tunes you get.
Of course, with all that air going in, it needs to go out. 5" mandrel bent exhaust kit. I bought my first one from Mark in Idaho. Was about $300 and sounded nice. I noticed lower EGT's after the larger exhaust was put on. Besides the nice sound, it added nice looks and got me plenty of comments.
Please, if anybody else has free or low cost mods, add to this list. I know there was a lot of talk about tank mods, cackle cure, wastegate modifications and more.
Old 02-19-2009, 06:50 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
Old 02-19-2009, 06:57 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Filter cover for the 6637 from Pete ($20)
CCV mod ($20)
Clean CAC boots, tighten clamps (free)
wastegate delete mod (free)
torque rocker arm/injector hold-downs to spec (free if you have a tq wrench)
GPR led mod ($10)
Scangauge (not necessary, but very cool $220)
Common Mods SSSimon Australia Chapter 15 10-21-2013 07:48 AM
6637 mod question tj01536 1999 - 2003 7.3L Power Stroke Diesel 40 07-24-2011 10:00 AM
Budget/DIY Performance Intake! Ronin 5729 6.4L Power Stroke Diesel 11 05-12-2011 07:42 AM
6637 filter mod nrskel78 1999 - 2003 7.3L Power Stroke Diesel 11 10-26-2009 02:15 AM
6637 mod done, what about mass air flow sensor??? matt21418 1999 - 2003 7.3L Power Stroke Diesel 4 07-24-2006 03:34 PM
Tags
73, 99, cackle, cure, easy, ford, free, gpr, led, mod, modification, mods, power, powerstroke, turbo, wastegate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
