How reliable are the 94-98 7.3's?
I would like a 99 to 04 ford with a older 12v in it. Commonly called the cumminstroke. My ideal truck. However, since I have no time and if I even tried to hint at another truck before the kitchen renovation, I would be living in the 5th wheel. Stinking black walnut cabinets, I could have puked when I got the bill for the millwork alone..... Good side to that is that i have to pull it with the truck....LOL
nope. its still 425. they didnt make any changes in the torque until the SD.
<TABLE class=wikitable><TBODY><TR><TD>7.3 L Diesel V8</TD><TD>1992-94</TD><TD>185 hp (140 kW)</TD><TD>360 lb·ft (490 N·m)</TD><TD>IDI</TD></TR><TR><TD>
7.3 L Diesel V8
</TD><TD>1992-94.5</TD><TD>190 hp (144 kW)</TD><TD>390 lb·ft (531 N·m)</TD><TD>IDI Turbo</TD></TR><TR><TD>
7.3 L Diesel V8
</TD><TD>1994.5-97</TD><TD>215 hp (157 kW)</TD><TD>425 lb·ft (575 N·m)</TD><TD>DI Turbo, Powerstroke</TD></TR></TBODY></TABLE>
7.3 L Diesel V8
7.3 L Diesel V8
Well i never said anything about a 6oh or a 6.4, personally any ford truck after 03 should be a V10. For me the ownship list from most desired to least goes something like this: OBS psd, 99-03 psd, 05+ 3v V10, 2v V10, 6.9 IDI diesel, 12v cummins, 7.3 IDI, then any newer dodge diesel, and lastly i'd take a VW Jetta TDI before a Tampax (oops i mean duramax).
if you want to build a good truck, its better to use a specialist on certain parts. if someone can build something better than you can, then using them will make your product better. chevy uses allison trannys and isuzu diesels. ford and dodge used dana rear ends. dodge uses a cummins engine. ford uses an international engine. etc.
that being said, ford and international jointly build the f-650's and 750's. but yet the only engine options are caterpillar and cummins.......if international would rather use a cummins than their own engine, that means they must be pretty good. and the only automatics offered on the 650's and 750's are made by.....allison. so to the original poster, both trucks have their good and bad points. both will last just as long if you take care of them. and both the cummins and the 7.3 are virtually bulletproof.
i didnt forget them, i just didnt want to type a laundry list of the crap ford has rolled out lol. or how about the cologne engine family of v-6s where the heads would crack if you just looked at them wrong. the 2.3 that the lifters would start ticking and need to be replaced before you could even get it home from the dealer. the pinto that would explode if someone rear ended you. the mustang that the gas tank would explode and cover all occupants with gas and fire in a rear end collision. the c3 tranny that the front seal would fall out causing all the fluid to drain out and fry your tranny before you knew it. the cruise control switches that would catch on fire and burn your car(or house) up. the ignition module switches that would catch on fire and burn your car up. had that one happen to me. its always fun to look outside your window and see your car engulfed in flames. the 5.4 that loves to shoot spark plugs through the hood. the cps on the 7.3 that will leave you stranded at any moment. we can go on with these for days. so replacing ball joints or a rear axle bearing on a dodge truck doesnt sound too bad when you really think about it. at least they dont catch on fire just sitting in your yard.
#28
7.3 L Diesel V8
7.3 L Diesel V8
7.3 L Diesel V8
7.3 L Diesel V8
#29
mine says 225 too and its a 97. but ive seen several that say 215. so not sure on that one, or where the extra 10 hp is coming from. but every site ive looked at has all of the obs rated at 215/425 and then jumping up to 250/525 with the superduty.
