Ok I was told by someone that they had done the reverse shackle on a 250 with the TTB axel. I keep hearing that it can't be done but can't grasp why. In stock setup when struck the axel moves up and forward. If it were reveresed ( up and back movement) wouldn't the horizontal movement of the axel be the same distance just reversed. Does the stock setup allow for forward movement and rear? Seems like the only thing that would be affected is the drop bracket bushings.
