Need help!! Please help v-10 guys!!
what a amazing site, just found it,
I have a 99 V-10 with a 06 front end, Love the truck.
problem is.... last summer as I was driving It just shut off, its like somone turend my key off,
as I driving I throw it in N and restart no problem and keep going,
some time it would do it 4 times in 2 miles, other time wont do it for 3 days,
of coarse took it in to get fix and it dident do it at all, The guys disconected my remote start,
Still doing it, The as it got cold out ( winter ) It did not do it for 3 months
And then a week ago it did it again, ( was warmer)
so im thinking it only happiens when its warm and wet,
any Ideas?????
thanks
Amazing site!
any Ideas?????
thanks
Amazing site!
Sounds like you are losing spark one way or another, if you were losing fuel the engine would sputter out. Could be electrical, when something overheats it starts to malfunction. It is weird that it starts right back up though if it is something like that. A loose electrical connection somewhere in the ignition circuit could do it, but it wouldn't seem to make sense that there would be a pattern involving temperature.
truck
Man this site is good!!!!
when u say unhooked, did they unhook every connection and leave the wiring exactly back to stock ???
my guess is they prolly just unhooked the power wire for the alarm...not sure if thats enuf removal..
like i said in my situation we completly removed the alarm.. as i didnt wanna go throu the hassle of figuring out why it wanted to randomly shut the vehicle off...
truck
Sounds like the crank position sensor.
Does it chug at all just before it shuts down? (losing fuel pressure).
Or, if it's just like it was shut off with the ignition key, that points to the CPS.
It could even be the ignition switch, but who knows.
Until it happens and won't start when cranking it over, and you actually FIND the problem, it's going to be a crap shoot
Definitely do. Not at all sure this is your problem, but worth looking into.
I've heard of this happening alarm installers thought to be really thorough and put an ignition interrupt relay in rather than (or in addition to ) just a starter interrupt relay.
As time went on, the relay points would get dirty or there half-arsed wiring starting going intermittent. Hit a bump, and the wiring or relay would interrupt the signal.
With an old fashioned analog ignition, no big deal. The engine would miss a beat and then go again. But with ECU controlled engines, some ECU's would see the momentary power interrupt and shut down all ignition.
If whoever installed the remote start did not solder or correctly crimp the connections (my experience is that at least 95% of "professional" installers do NOT have a clue how to make a reliable connection), then odds are at least one is going intermittent by now - and could be sending a confusing signal to the ECU.
truck
it just shuts off. like you turend me key, then throw it in N and restart and keep going,
im geting good at it know!
LOL
CPS = Crank position sensor. If the sensor fails, the PCM doesn't know the engine is turning, won't fire the injectors, and won't fire the spark plugs. And, it won't throw a code.
Now while it would seem that if it was bad, it wouldn't let the truck restart, many times when the engine shuts down, it restarts right away.
This happens with the 7.3 diesel. Same exact failure mode. So bad, Ford recalled the CPS sensor for the 7.3. For the record, the V10 hasn't really had a known issue with the CPS, but that's what your problem sounds like. Of course, it could be other things, so don't just run out and spend $'s on a CPS right away unless you really REALLY can't find the problem.
(The V10 also has a cam position sensor, I think just so it knows exactly where every piston is. It only triggers once per cam rotation. The crank sensor will only tell it any one cylinder needs to fire. With the cam sensor, the PCM also knows WHICH cylinder is firing.
