mushy brake and clutch
Old 02-18-2009, 01:38 AM
2pazr's Avatar
2pazr
2pazr is offline
so i when to blled the clutch and brakes first noticed there was no fluid at all bone dry empty resivor filled them up pressed pressed ... nothing open bleed nipple nothing undid hose off of master clutch pumped nothing even dripped out. Do i need new ones or am i just not doing something correctly?
Old 02-18-2009, 07:16 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 2pazr
so i when to bled the clutch and brakes first noticed there was no fluid at all bone dry empty reservoir filled them up pressed pressed ... nothing open bleed nipple nothing undid hose off of master clutch pumped nothing even dripped out. Do i need new ones or am i just not doing something correctly?
This is a 1957 thru 1960, correct?
Both the brake and clutch cylinders are prolly leaking, you can buy repair kits for both of them.
Post back with the exact year, and whether it's a F100 or F250, and I'll give you the info.
Please...when asking questions, list all the pertinent info: Year, Series, Engine, etc.
Old 02-18-2009, 07:40 AM
52 F3's Avatar
52 F3
52 F3 is offline
If this is something that has been setting for a while the pistons may be stuck down in the cylinders and not moving. Just the pedals moving when you pump it. If so you will probably need new cyls.
Old 02-18-2009, 12:35 PM
2pazr's Avatar
2pazr
2pazr is offline
its a 60 f100 it has a 292 and 4 in the floor convertion that was done by my dad 25+ years . I dont know what the tranny is or the year of the egine he said it was from a 57 tbird?? what about new hoses one of the metal brake line that runs under the bell housing to the front rght wheel appers to be crimp shut like they crushed it when installing the trans is there any way to open it out or get it fixed or replace it?
Old 02-18-2009, 12:54 PM
NumberDummy
The hose that routes from the master to the clutch slave cylinder was sold by Ford as a separate part (it's now obsolete), but all the steel brake lines had to made made up from scratch out of bulk steel tubing, as Ford never sold these lines at the parts counter.
There may be some aftermarket reproduction parts dealers making up steel brake lines. I know some have done this for the 1968/79's.
You can buy new clutch master and slave cylinder repair kits from NAPA. Obsolete parts vendors have lots of the original genuine Ford kits which are now obsolete.
They also have the master to clutch slave line. I've found dozens of these kits and the line in the past for members.
With new kits, you can hone out the cylinders and install the new seals, which is cheaper than buying new cylinders, which were obsoleted by Ford 20 years ago.
Old 02-18-2009, 01:07 PM
2pazr's Avatar
2pazr
2pazr is offline
the rubber hose from the master to clutch slave is good but brake steel line is crushed ?where can i get about 4 feet of the tubing and connectors? do i reuse the connectors?
what about the kit is there a special one i need or are they pretty much the same? do you suggest a rebuild or a new set?
Old 02-18-2009, 01:39 PM
NumberDummy
I'd check the repro parts sellers to see if they sell any of the steel lines, because making up the lines up from scratch can be expensive due to the tools involved.
You need the correct diameter steel tubing, the nuts and ferrules, a flaring tool and a tubing bender to make these lines up. None of the old parts can be reused.
The master & slave cylinder seal kits are two individual kits, as you can see.
C3TZ7560B .. Clutch Slave Cylinder Seal Kit / Obsolete / Fits: 1960 F100/600 & 1961/62 F500/1100.
GREEN SALES CO. in Cincinnati OH has 15 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 10 = 800-546-7278.
PARTS INTERNATIONAL in Farmers Branch TX has 10 = 888-727-0418.
B7C7578A .. Clutch Master Cylinder Seal Kit / Obsolete / Fits: 1957/60 F100/1100.
GREEN SALES has 10.
MILLER OBSOLETE has 3.
PARTS INTERNATIONAL has 4.
B7TZ7A512A .. Tube-Clutch Master Cylinder to Clutch Slave Cylinder / Obsolete / Fits: 1957/60 F100/950.
PARTS INTERNATIONAL has 2.
ANTIQUE AUTO SUPPLY in Arlington TX has 3 = 817-275-2381.
BOB ALLEN FORD in Overland Park KS has 2 = 800-676-0675.
KINSEL L/M in Beaumont TX has 2 = 800-816-2894.
Old 02-18-2009, 02:04 PM
2pazr's Avatar
2pazr
2pazr is offline
so thanks alot for your time and help is there a break rebuild kit or should i just get a new brake master? and i need one of each sets master and slave if the tube(the hose?) is still good do i need to replace it? i dont want to sound like an idiot when i callem!!
Old 02-18-2009, 02:52 PM
NumberDummy
When you call, just read off the Ford part numbers I typed.
It depends on the condition of your brake master cylinder whether you need a overhaul kit...or not.
If it's not pitted inside, you can replace the individual parts that come in the kit.
If it is pitted inside, you need another master cylinder.
B9C2004A .. Master Cylinder Overhaul Kit / Obsolete / Fits: 1957/60 F100 2WD / 1959/60 F100 4WD.
GREEN SALES has 2.
MILLER OBSOLETE has 4.
DENNIS CARPENTER OBSOLETE PARTS has 12 = 704-786-8139
NOTE: Check with your local NAPA or indie autoparts store to see if they have kits....before calling these obsolete parts vendors.
The local stores will be cheaper, obsolete parts vendors will...in most cases be much more expensive.
The Ford part numbers might be able to be crossed over to the brands local autoparts stores sell...they might not be.
Old 02-20-2009, 12:49 PM
2pazr's Avatar
2pazr
2pazr is offline
yes the inside is pitted its gritty, like rust or sand and the cluct is also does this mean i need a new slave as well? would it probably just be better to get a new set of everything i need masters and a new cluct slave?
