1975 Ford F150 460 Timing chain cover
Hello all,
I have what I originally thought was a leaky gasket on my timing chain cover(leaking coolant) just above the fuel pump against the engine block. When I removed the timing chain cover I noticed a small hole in the top right hand corner of the timing cover on the water pump side. Not being a mechanic, I thought that this hole was my problem. I have tried finding a timing cover from the local wreckers, here's my problem. Every cover I have found has this same hole? Everyone has told me this hole is normal but it looks to me that it has been caused by corrosion. Can anyone tell me if this small quarter sized hole is normal.
bruincup
1975 Ford F150
Club Cab / Trailer Special
460 / 116000 miles <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
bruincup
1975 Ford F150
As to not cause confusion, the direction of any part is done from sitting in the driver’s seat and looking out at the engine. So if you were standing in the front of the vehicle looking at the engine the valve cover on the right would actually be the left valve cover. Some people say the passenger side or drivers side to help clarify which side you are actually referring to, but this could also cause confusion if you were talking to an Aussie.
But if the hole is on the left side behind where the impeller blades of the pump would fit, then it is corroded. This is very common to the 460 and the thing should be replaced. I have tried to patch them with little success. It is far easier to just replace them when you consider all of the trouble it takes to get them on and off. They are usually less than a hundred bucks.
Bobcat7
08-12-2009 04:22 PM
probie
02-03-2009 01:49 PM
