1978 351W out of a couger hp????
I just picked up a junkyard special 351W out of a 78 couger it has a 2brl carb I was wondering what was the factory hp and torque and what can I do to make it perform better? I plan on a performer intake and 600 edelbrock carb and some headers any other suggestions???
on
Get a set of E7TE's off a late model 5.0/5.8 or better yet GT40's off an Explorer/Mountaineer 5.0, all of these will raise compression and the GT40's flow better. The cam you select depends upon your intended use and vehicle. Something with 260-270 adv duration and about 1/2" lift will produce a broad powerband, a little less duration for more torque, a little more duration for more peak HP.
Yes for the most part I want to switch out the rear end and put drop spindles up front 2-3" but don't know where to find them yet? I want to keep most of the truck original except for the paint, interior and rims&tires of course! I would like to put some custom rims on that is why I need a different rear end and new spindles and hubs up front! Does anyone know what,where or how to do this what parts to use??
I dont know about the dropped spindle deal, it's an I-beam front axle. They sell dropped axles,but it would be a 1/2 ton deal. You may want to find a donor vehicle and swap out the front axle and springs. However there are companies out there that can drop your axle. Go to jalopy journal.com click on H.A.M.B. Someone there might be able to lead you in that direction. Good luck with your project!
bountyhunter1650
04-07-2016 06:59 PM
peakster
15
10-28-2014 07:32 PM
bulldogcountry1
10-07-2006 03:09 AM
