Is it possible to put dual alternators on a 5.4?
I have a 97 e250 with the 5.4 that is a work vehicle. We need to have AC power in it so I'm installing a 100W inverter. I'd like to add a second battery bank for the inverter with a seperate, high output alternator. Is it possible to add a 2nd alternator to this engine?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
As for the addition of an extra alt, it can be done but more importantly is the cost and belt configuration.
I need to run a laptop and a printer pretty much all day and a jig saw and a cordless tool battery charger occasionally.
Yes, I did mean a 1000W inverter.
The big thing is that I need the laptop to keep running when we're at a service call and the engine is off. Sometimes that's only 30 minutes but most of the time its an hour or two. I plan on putting a couple of deep-cycle batteries in to run the inverter and would really prefer to have a seperate alternator to charge them instead of installing a battery isolator, if it isn't too much of a hassle.
Add a 2nd battery and battery isolator to power a inverter. I use a Igo power adapter for my notebook in my truck. iGo.com iGo everywhere130 notebook power adapter It can be used in a vehicle or as a wall adapter.
I saw the ideal set-up at the DRMO site here in HR. It's a Heavy Duty E-350 that was used for some kind of Special Ops. There was radio and computor racks in the van with a desk and all in the back. In the far back, right at the rear doors the contractor cut a hole in the floor and mounted a Kubota diesel powered generator under the floor. I was, without a doubt the neatest install I've ever seen. Sorry, no pics.
2003SuperDuty7.3
Electrical Systems/Wiring
08-15-2014 02:06 PM
nojoke327
07-05-2014 10:00 PM
speakerfritz
1999 to 2016 Super Duty
02-07-2014 09:04 AM
MrNightman
01-07-2014 05:14 PM
bismic
05-25-2010 08:41 PM
