Smog and EGR removal once again!
Just remove the tube completely and plug the holes so you know there's no leak anywhere, you need a 5/8 x 1" coarse thread bolt and a copper washer to seal it. Should look like this when you're done.
You can then delete the air pump and all the plumbing and valves attached to it. The only thing that should stay are the TAB and TAD solenoids over by the coil. The vacuum lines should be removed but you want them electrically connected.
The whole vacuum harness is pretty tidy and can be removed from the motor intact. There is a red line that goes from the intake around the back to the vacuum resovoir over on the passenger fender. Another red line comes back and Y's to the TAB and TAD solenoids. With the tape and wire loom removed you can trace these lines and pull them out of vacuum harness.
And the EVR, can that be removed or no? I see it says TAD and TAB solenoids are the only ones that should stay, but I'm simple
Thanks!!
i tried the hardware store, count find anything that fit. wound up putting a quarter under the compression fitting from the egr line. seems to plug it up well, we'll see about later on but this will work till it fails.
but dang getting the bolts off the back of the heads was a major PITA!! and i still cant get the plug bolts in. all i could find where 5/8 1.5" long so i had to cut half an inch off. they wont thread so im hoping if i just keep working on the thread face of the bolt with a file ill get them it thread in
and dang these old colored vacuum lines! they break just by looking at them! guess ill have to replumb all those with new line
-Rod
finally got them in
thats what i figured the problem was... should've used a battery brush though, the brush i used was not up to the task.
Originally Posted by White Max
The threads in the head will have a ton of carbon buildup on them that makes it a chore to get the bolts to thread in. I used a battery brush to clean the holes/threads out before running the bolts in, and that worked like a charm.
Bump for this amazing information. I'm in the process of installing Headman Headers right now, and came across that seized tube stuck near the catalytic converter, and started swearing as I didn't realize these trucks had the same 'good for nothing' emissions junk. (I moved to a Province in Canada that doesn't have emissions because let's be real, it doesn't protect the environment, it just drives up the costs of cars and hopes you go back to the dealership for repair)
I'm sawzall'n everything out of the truck right now, but it looks like this operation is similar to the Nissan 240sx I also did this to. Block it off, then fool the computer (in my case with the Nissan 240sx I ran a stand alone Engine managment from AEM)
I'll hopefully have a video on what I end up doing with my 93 F250, 302.
So the bolt that fits those holes to plug them has a 5/8” shank? Does that go for an ‘88 351w?
#28
It's in the back of the heads, and should be independent of what block you install them on.
And regardless of what people might claim, let's face it, AIR DOES help reduce emissions, if you have the rest of the equipment.
I had to install these bolts onto a set of Edelbrock heads I installed onto my 1969 Mustang, which does not have the rest of the emission control system. And boy, does that engine stink, so much so that I don't like to drive it, regardless of how I tune it. If I could afford it, I would get a whole set of cats, AIR pump, and the plumbing to hook it all together so it would stop being a gross polluter.
85F2502WD
48
04-02-2021 03:33 PM
Alexinflorida
06-14-2017 03:12 PM
94150
15
01-25-2017 03:41 PM
MrFord619
11-14-2016 09:57 AM
