1989 5.8L:35-255-5 Comp Cam
02-16-2009, 11:13 PM
on
Hi, I have a recently rebuilt, by me 4k miles ago, 351W in a 1989 SD EFI F250. I installed the mentioned Comp Cam camshaft and am wondering what idle vacuum I should expect. I also have no air pump or plumbing, short tube headers, no cats, true dual exhaust and a KN FIPK on this truck. The idle vacuum is wavering slightly at 15-16 in. hg., is that usual for this cam?
Thanks
02-17-2009, 11:56 AM
what does the spec sheet from comp say? have you pulled codes to see if something else might be having a problem?
02-17-2009, 09:34 PM
on
The cam card has no idle information, rpm range, or anything like that-just lifts, duration and open/close specs. I degreed the cam and it is installed as the card called for. There are no codes as of about a week ago and the MIL is not on.
02-18-2009, 10:56 AM
why did you degree the cam. it should have been installed strait up. you can still have codes even though the CEL isnt on.
02-18-2009, 10:32 PM
on
I degreed the cam to be sure the cam was ground correctly and I did install it straight up. It is at 0 degrees advanced and 0 degrees retarded..in other words, straight up. There must be someone else who is using or has used this cam that knows what their vacuum is/was... please?
leviarps
01-10-2017 07:12 PM
ncovelli
04-16-2016 10:25 PM
retired ironworker
03-29-2014 10:03 AM
RadioControlGuy85
03-09-2014 02:19 PM
armynavyguy
Modular V8 (4.6L, 5.4L)
07-08-2007 04:01 AM
