Crown Vic swap to F100 questions - Ford Truck Enthusiasts Forums
Old 02-16-2009, 11:19 PM
bman1080 bman1080 is offline
bman1080 is starting off with a positive reputation.
I have a 1953 F100 and a 1986 Crown Vic. I would like to know what all I will need and is compatible to swap into the 53? I am considering keeping it fuel injected. Also will any of the brakes work on the 53?
Thanks
Billy
Old 02-17-2009, 02:18 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Well, in general:
The brakes will work in the 53 if you make them work.
As far as dropping the CV engine in the 53 for a start, you'll need to convert it to 12 Volt negative ground. You'll need new motor and transmission mounts - drive shaft of course. And the usual hook up mods - shift, throttle, ignition, probably modify the exhaust, radiator connections, transmission cooler.
There's probably tons more but that's a good enough start. You and 55F350 will probably get along famously.
Old 02-17-2009, 09:00 AM
thepitshop's Avatar
thepitshop thepitshop is offline
thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.
this is what i grabbed, the complete front end, gutted the car and grabbed the complete harness, grab the master and booster, rear end, steering column, front seat if you want, i`m not using them because i feel there a bit too big for the cab, fuel lines, i haven`t got to the radiator part on my truck but by just laying it in place looks like it also can be used, and i think thats about it! i`m using a mustang fuel tank and will probably try and modify the crown vic fuel pump to fit in it, wiper motor will also be modified and fit to the f100 wiper system, and i think thats about it!
Old 02-17-2009, 09:49 AM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
Where are you located Bman?
Old 02-19-2009, 01:25 AM
Thanks I appreciate all the info. I am in Austin, Texas.
Old 02-19-2009, 07:52 AM
tacson's Avatar
PM or look thru my gallery. I will help you all I can.
Crown vic front end swap Carmax 1961 - 1966 F-100 & Larger F-Series Trucks 5 08-23-2016 02:49 PM
1970 F100 Build Crown Vic Swap 70f100bb 1967 - 1972 F-100 & Larger F-Series Trucks 31 07-04-2016 12:51 AM
53 f100 crown Vic front end DasHaas 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-31-2014 06:00 PM
Crown Vic swap in 1966 f100 1967leroy General Automotive Discussion 3 04-03-2014 08:49 PM
How much drop on a crown vic swap Ikestang 1967 - 1972 F-100 & Larger F-Series Trucks 1 01-02-2014 10:24 PM
Tags
1948, 1955, 72, crown, f1, f100, fi, ford, motor, swap, vic, victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
