Found the Delayed Acc. wire - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-16-2009, 10:13 PM
Brett in KS Brett in KS is offline
Brett in KS is starting off with a positive reputation.
I finally got tired of listening to static after I shut my truck (and my Sirius radio) off. I had mounted a power point jack under the big panel under my steering wheel and powered it up with the blue w/ white wire ford supplied for accessories. It worked good except it was only hot when the key was on. So when I would shut my truck off, the radio stayed on, and the Sirius shut down.
Static.
I finally got tired of that and went hunting for the delayed acc. wire so my Sirius would stay on until I opened the door. I unbolted the fuse panel and pulled it out far enough I could use my test light on the back of the connectors on the back side where the wires come in. After about 20 min. of playing with it, I finally found it. the delayed acc. wire is Blue with a black stripe. It is one of only 2 wires on the harness. the other wire is green. They are on the left side of the fuse box in the middle and they are bigger wire (maybe #14 or 12 gauge). I just used a suitcase connector to connect my power wire that goes to my underdash power point.
I did a search looking for the above info and couldn't really find anything definte before I started messing around, so I thought I'd post my results so that it might help someone else also.
Old 02-16-2009, 10:22 PM
I forgot to say that my truck is a 2004 F-250 Reg cab.
Old 02-16-2009, 11:26 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Great info and thanks for posting. My Sirius is set up the same way yours was and I'm getting ready to change it over like you did. This will make it easier now!
Old 02-16-2009, 11:32 PM
alamojimmy's Avatar
alamojimmy alamojimmy is offline
alamojimmy is gaining momentum as a positive member of FTE.
Excellent work Brett. I am normally not a fan of people from Kansas but you have impressed me. (Kidding about the Kansas thing) Seriously, it is people like you on this site that have made it what it is. Very helpful. I know I will use the info you provided when I install my Sirius. Thanks Brother.
The Kansas thing is due to my being a Texas fan. The whole Big 12 rivalry thing.
Old 02-17-2009, 07:26 AM
Downriver Thunder's Avatar
Downriver Thunder Downriver Thunder is offline
Downriver Thunder is starting off with a positive reputation.
When I had my XM installed I don't know where he powered it from but it stays on until I open the door. Maybe he powered it from the radio power lead.
Old 02-17-2009, 06:02 PM
tawilson1152's Avatar
tawilson1152 tawilson1152 is offline
tawilson1152 is starting off with a positive reputation.
Quote:
I used the radio power to run a relay which controls the accessory power outlet. My Sirius tuner gets pretty warm so it may draw enough juice to blow the radio fuse if it was tied in direct. Maybe not.
Old 02-18-2009, 10:28 AM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
A little additional information since the subject was brought up:
The light blue/black wire is the main power lead for the power windows, moonroof, and rear slider. It is fed by fuse 601 in the central junction box and is fused with a 30 amp fuse.
There are also two pink wires coming off of the central junction box that are both fed by fuse 42, which is rated at 15 amps. One of these wires is the power circuit for the power door lock switch, and the other runs to the radio and serves as the "turn on" signal. The radio uses very little current on this circuit as it is mainly powered by fuse 11. The pink circuit can be used for light-load accessories and as an amp turn-on lead.
Old 02-18-2009, 11:28 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
When I hooked up my XM receiver, I took out the radio and found the delayed power wire feeding it. I took one of those cigaretter lighter splitters, cut one of the sockets off and tapped it into that power wire and a ground. Then I could just plug my XM lighter power cord into it. It's all stuffed up behind the radio out of the way, just the power wire and antenna wire coming out of the access panel under the steering wheel.
Old 02-18-2009, 07:41 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Anybody know what wire to use in a 2007 with the 6.0L?
I need a wire to hook up power for my two headrest monitors. I tried hooking them up to the amp turn on wire from my head unit but eveidently running them and the amp pulls too much current and the head unit shuts off power to that circuit. So now I'd like to find this wire so they will stay on until I open the door.
Old 02-18-2009, 08:45 PM
The wire colors are the same and the circuits are laid out similarly on the 2007. You could use the LB/BK for the power windows, it uses a 30 amp circuit breaker that year. If you trip that, the breaker resets after it cools.
Or, you could just wire in a relay of course, and use the pink audio wire as the control.
Old 02-18-2009, 08:53 PM
FireMe,
My truck doesn't have all that fancy stuff like a moon roof or power sliding rear window. It does however have power windows and locks. is the end of the wire that goes to the fancy stuff taped off somewhere, or does it just end in a harness plug somewhere. Just kinda curious.
Beerstalker,
Are you able to unbolt your fuse panel? I'm not sure about the 07's but If it was like mine all it takes is a 10mm (I think) socket and 4 bolts and you can pull that sucker down and see the back of all the harnesses coming into it. Then use a test light and play around and maybe you can find something. First I'd look for the blue w/ black wire over on the left side of the back of the panel. Its on a 30 amp fuse - surely thats big enough for your monitors?
? about key in acc, door open and dome light Bergerson 1999 - 2003 7.3L Power Stroke Diesel 5 11-07-2014 10:59 PM
2.5kW inverter, RF equipment, Rack install (Note: Many images to load) TRENT310 1999 to 2016 Super Duty 13 10-26-2014 03:46 AM
84 Factory radio wire colors/diagram needed CountryBumkin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-17-2012 12:23 PM
Manual High Idle and Glow Plug Wiring Idea BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 03-01-2010 06:54 PM
2002 F-250 Sirius Radio Installation Adirondacker 1999 - 2003 7.3L Power Stroke Diesel 16 06-01-2008 01:58 PM
Tags
06, 2008, 2009, 2010, acc, accessory, delayed, duty, f150, f250, ford, fuse, radio, super, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
