Help!Door and Rear Cab corner
I need some help.My painter replaced the rear cab corners on my 53 and is telling me the back of the doors wasn't a flush fit or in line with the cab corner. My door sticks out about a half inch more than the cab corner. I told him i thought they should be even with each other. Almost a straight edge.Who's wrong me or him. Need some pictures from someone please , to satisfy my curiousity. He said if their even they've been modified and that they all look like this stock. I disagree. i hope I'm wrong . He wants to bend the rear lip of the door an 1/2 inch to fix it. Both doors came out like that.
O.m.g.
Don't let him bend the doors.Some cab corners are junk Contact Midfifty pickups Email midfifty.com Some cab corners only the curved edge is good the door jam edge is junk.My doors are flush and that the way they came from ford.I think your body man should find another job like scrapping cars. Dave
I cant reason with this guy . He's right and I cant prove him wrong. I got my cab corners from midfifty ,the one that didnt have a hole for the gas tank .Looks like I'm gonna be stuck with a screw up from a F##k up! I'm really pissed and dont know what to do. Learned the hard way I guess. Any Truck lawers out there?
Just stop and walk away from the truck for awhile.Does the door follow the cab line all the way down until it meets the new cab corner?If not then you might have an adjustment at the door striker.If it does meet flush from cab to door until it meets the new corner then check that the rocker panel to door alignment from the bottom looking up to see if the rocker stays in line with the door when closed.If the rocker was buckled in due to the rot from the cab corner and not noticed this could be the problem.Don't mess with the door It's cheaper to put a new corner on . PS. try putting a straight edge against the door and cab edge and drag it down until it meets the new cab corner this will show you the high and low points
