Turbonetics high flow turbo outlet 7.3 powerstroke - Ford Truck Enthusiasts Forums
Old 02-16-2009, 02:11 PM
robjs111 robjs111 is offline
robjs111 is starting off with a positive reputation.
Wondering if anybody has installed a high flow outlet flange on their 7.3 powerstrokes and if so did you see any differences?? I have read that the elimination of the EBV will improve flow, reduce exhaust backpressure and help to lower Exhaust Gas Temperatures. Also would the gains be different on a stoke turbo vs and upgraded turbo like the turbonetics gtp38? Thanks.
Old 02-16-2009, 04:04 PM
DieselCamper01's Avatar
DieselCamper01 DieselCamper01 is online now
DieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud of
No idea. Here is a bump
Old 02-16-2009, 05:54 PM
jwhitetail jwhitetail is offline
jwhitetail is gaining momentum as a positive member of FTE.
Most aftermarket turbo's will be better than a stock turbo, at lowering egt's and improving air flow and boost. I believe Turbonetics has had some problems with there turbo's that fit the 7.3 PSD. Look into a Garrett or ATS.
Old 02-16-2009, 06:03 PM
what kind of problems did they have? is there a big improvement with doing the ebv delete? thanks.
Old 02-16-2009, 06:09 PM
I believe it was bearing problems, but don't hold me to it, yes deleting the ebpv will improve flow.
Help with wastegate sensor Nolo263 1999 - 2003 7.3L Power Stroke Diesel 14 10-01-2015 07:55 AM
GARRETT TS04 T-58 TURBO 7.3 IDI !!Help!! Chemgrad Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 112 05-08-2013 08:48 AM
Turbonetics high flow turbo outlet? Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 5 08-23-2012 11:45 AM
Blown Turbo Part II, With Pics PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 13 07-01-2010 01:05 AM
Turbonetics Turbo white Buffalo 1999 - 2003 7.3L Power Stroke Diesel 14 11-20-2008 07:35 PM
Tags
19992003, 73, diesel, differnence, ebv, exhaust, flange, flow, ford, garrett, high, outlet, power, psd, stroke, turbo, turbonetics, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
