Suggestions for a donor fuel tank for my 52
Do a search of this site for "tank" or "mustange" you'll find numerous post about this subject. Also check out the post at the top of the main '48-60 board:
https://www.ford-trucks.com/forums/6...-articles.html
Just to more add on to what Bob was saying, the specific link to the gas tank (and the one I used when installing mine) is https://www.ford-trucks.com/article/...1953_F100.html
Always a balancing act,……….. and one that I have not made yet? .......................What are you going to do?
Thank you.
Handn't taken the fuel sending unit issues into account so big thanks for the heads' up, Old F1. Thought about having a filler in the left rear fender, hidden behind a door.
Anybody tried that with much success?
Keep those tricks and tips coming, Guys. You have been a huge help in all my questions. This is a fantastic website for first-timers, like me. The best.
Stu
Stu
After all my fuel problems I had, I would suggest a poly tank from Summit, Jegs, etc. No rust to worry about. Nearly all drop in sending units for aftermarket gauges would work and you can just strap her in. If you do use a stang tank make sure you line it first so it doesn't rust which usually drives the cost of the tank up. I went through two tanks and 5 fuel pumps to learn the hard way. Good luck.
I have installed a 1974 GMC 4X4 saddle tank between my rails.
https://www.ford-trucks.com/user_gal...210102&width=1
It still give clearance between drive shaft after install. Thinking about installing a safety ring for the drive shaft.
My original tank had a leak line around 3/4 full, then the cab smelled of gas.
Regards, Dale J.
Regards, Dale J.
Received 4,130 Likes
on
I'm using a tank from a 73 Chevy blazer, will fit between the frame rails no problem as both the chevy and ford measures 34 inches. I just modified the filler tube to suit my needs. I haven't bought my gauges yet so shouldn't have much problems matching a sending unit. I searched www.gastanks.com to get measurements and decided from that.
A buddy of mine here in town is building a 48 truck and used a poly fuel cell, looks great and fits nice. He is going to put the filler up through the center of the wood floor. The one he is using is a 14 gallon but if he can get 10 mpg that 140 miles and by that time you would be ready to stop and get out stretch anyway.
