99 7.3L Turbo Diesel Power Loss and Hissing Sound - Ford Truck Enthusiasts Forums
Old 02-16-2009, 12:22 PM
PigDiesel9 PigDiesel9 is offline
PigDiesel9 is starting off with a positive reputation.
Question 99 7.3L Turbo Diesel Power Loss and Hissing Sound
I have a 99 F350 with a 7.3L Power Stroke turbo diesel. when I accelerate to a steady RPM I hear a hissing sound like air is being released. At the same time the engine seems to lose power and the rpm's drop. This happens anytime i hold a steady rpm weather driving or in park. If I accelerate it stops until the RPM's hold steady again. Also, on an immediate cold start it doesnt seem to do it. After 30 seconds or so, as the engine warms up the problem appears. Does anyone know whats wrong? Any feedback is greatly appreciated.
Old 02-16-2009, 12:30 PM
harleydude03 harleydude03 is offline
harleydude03 is starting off with a positive reputation.
sounds like a boost leak. you have air leaking out around boot or something in the system
Old 02-16-2009, 12:33 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
It is your Exhaust Back Pressure valve. It closes when the truck is cold. Normal operation when the oil temp is below a set point. Let the truck warm up more before driving it and you should not see it when driving.
If its still doing it when on the road and warm then the EBP sensor is most likely plugged. Clean the tube and or replace the sensor.
Old 02-16-2009, 12:48 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Welcome to FTE.
Here is how to clean the exhaust tube and sensor. click here. It does sound like the EBPV is closing. I have the decel on my tuner and thats what it sounds like when the valve closes.
Old 02-16-2009, 01:03 PM
I had a buddy under the truck to listen and he said it sounded like the air was dumping into the exhaust when it was making the noise.
Old 02-16-2009, 01:16 PM
05chop 05chop is offline
05chop is starting off with a positive reputation.
When you try to drive it does it pour out black smoke from the tail pipe? Look in this part of the turbo this is where this warm up valve sits
Old 02-16-2009, 01:29 PM
no it doesnt have any black smoke. The exhaust seems very normal.
Old 02-16-2009, 01:36 PM
Look at the blue hose in this picture then check all large pipes coming out of turbo into the air cooler and out.There could be a hose clamp loose or off.
Old 02-16-2009, 01:43 PM
I will check it out, thanks. It feels like a valve or sensor operating incorrectly. Could this problem be anything other than the mentioned ebp valve considering the symptoms? Thanks for the help everyone.
Old 02-16-2009, 01:49 PM
If it was a sensor I would think you have a check engine lite! Just to be safe get your truck scanned and check for codes. Im not sure about your mechanic ability but yes the exhaust warm up valve can stick shut and cause problems like low power.
Old 02-16-2009, 02:09 PM
Your right, there is no engine light, no pending or prior codes and all the monitors are running. Some vehicles dont throw codes right away. It could take extended driving to get a cel to come on.
Old 02-16-2009, 02:19 PM
Could be you are listening to the turbo whine at the air cleaner and exhaust? Need more info here if you checked all this out if no smoke is present or no codes.
Old 02-16-2009, 02:21 PM
Is there any exhaust leaks?
Old 02-16-2009, 02:25 PM
h2omotorsports h2omotorsports is offline
h2omotorsports is starting off with a positive reputation.
I have been having the same problem. When I am at a constant speed on the freeway the boost pressure goes way down to like 1psi but when the engine gets up to temp it goes away. It has more of the hissing sound while in town when the engine is at lower RPM but only while at constant throttle. It goes away when I am completely off throttle or when I accelerate. It was a big problem up untill last week when it got up to 50+ outside and then it did not happen. It is probably the EBP sensor and I will be cleaning it out in the next weekend or 2.
Old 02-16-2009, 02:37 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
That's more than likely the EBPV doing its job. Once the truck is warm, it quits doing it, right? Completely normal operation in the winter...
1996 7.3 on cold mornings has a prominent "hiss" and draggy power at low throttle, why? thechainsawman 1987 - 1996 F150 & Larger F-Series Trucks 5 11-15-2016 11:46 AM
Powerloss/Hissing Problem Northstar55 1999 - 2003 7.3L Power Stroke Diesel 5 04-20-2015 10:16 PM
Help Not building boost? Griffin9 1987 - 1996 F150 & Larger F-Series Trucks 1 02-20-2015 01:44 PM
Help ,,,99 f350 7.3 liter ,, hissing sound when super cold till full operating temp Determined99F350 1999 - 2003 7.3L Power Stroke Diesel 15 01-07-2015 11:52 AM
Hissing sound HELP Big D-F350 1999 - 2003 7.3L Power Stroke Diesel 29 11-19-2014 12:34 AM
Tags
2001, 60, 73, cold, coming, f250, ford, hissing, lake, loss, pipe, power, sound, symptoms, tail, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
