99 7.3L Turbo Diesel Power Loss and Hissing Sound
Old 02-16-2009, 01:38 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
You will not see much boost on the gauge without a load on the engine. Start climbing a hill and you can watch the boost rise.
Old 02-16-2009, 01:43 PM
PigDiesel9's Avatar
PigDiesel9
PigDiesel9 is offline
it does not go away once the truck is warm. Is the problem still gonna be the ebpv ?
Old 02-16-2009, 01:45 PM
h2omotorsports's Avatar
h2omotorsports
h2omotorsports is offline
That's more than likely the EBPV doing its job. Once the truck is warm, it quits doing it, right? Completely normal operation in the winter...
Yep thats what I thought.
Yes I understand this but at 70mph on the freeway I always have about 4-5psi of boost when the truck is cold its only 1-2. Everything gets better once the truck is warmed up. So Im sure it is all the EBPV just doing its job.
Old 02-16-2009, 01:54 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
So it does this all the time? The EBPV takes a minute or two to kick in, but once it does, it shouldn't take more than about 10 mins for it to quit doing it.
Old 02-16-2009, 10:00 PM
aldridgec's Avatar
aldridgec
aldridgec is offline
Could it be really bad uppipe gaskets?
Old 02-16-2009, 11:27 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
It's his EBPV as far as I can tell. Mine did the exact same thing.
One way to find out for sure is go underneath your hood directly in front of the HPOP. There's a little plug behind one of the serpentine belt idlers. Unplug it and it the problem stops then BINGO. You've got an EBPV problem.
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
There's Guzzle's writeup.
The following users liked this post:
Old 02-17-2009, 10:02 AM
PigDiesel9's Avatar
PigDiesel9
1999 Power Stroke Power Loss Problem *SOLVED*
My 99 F350 7.3L was losoing power, rpm's and I could hear air pressure releasing from the driver side of the engine. I posted a thread yesterday. A few of you guys told me most likely the EBPV was bad. Last night I pulled the sensor and noticed the EVP tube has never been removed/cleaned in more than 144,000 miles and 10 years. It was about 90% clogged and had a pebble size whole in one of the bends. I went to the dealer, got a new tube (they had in stock) for $50. and replaced it. The sensor wasnt bad so I didnt change it. Afterall, its easy to get to if I had to go back and do it. Problem Solved. The truck runs great and even starts easier in the morning. Im not familar with diesels and never would have gotten this done on my own. Thanks for everyones help!
Old 10-10-2009, 08:50 PM
j74250's Avatar
j74250
j74250 is offline
mine does this exact same thing but even after its up to opperating temp. i have replaced the pipe and cleaned the manifold port and the sensor and the small tube between the sensor and the pipe. any other ideas??
Old 10-10-2009, 10:34 PM
FireMe's Avatar
FireMe
FireMe is offline
Did you verify that the valve is actually open and not stuck closed by looking at the linkage? It is not unheard of for the valve to get stuck in the closed position, or you could have a problem with the EBPV solenoid or wiring.
Jay
Old 10-11-2009, 12:09 AM
j74250's Avatar
j74250
j74250 is offline
Jay
yes, i can see it opening, and closing
Old 10-26-2009, 04:34 PM
Old and Busted's Avatar
Old and Busted
Old and Busted is offline
Guys, while cleaning my EBPS tube and sensor I found a crack in the tube. It's rotted and junk. 10 years of New England winters...Hate to beat a dead horse here, but I'm assuming I'm OK to drive the truck without the tube inplace to the dealer to pick up a new overpriced tube? (15mi)
Old 10-26-2009, 06:49 PM
7.3 Rocket's Avatar
7.3 Rocket
A lot of trucks don't even use the EBPV any more. If you don't mind waiting a little bit I'll ship you my EPBV tube. Mine was rotted into 2 pieces from rust so I got a new one this spring. Since then I've deleted my EBPV so I've got no use for it. It's 40 or 50 dollars for a new one from Ford.
  #28
Old 10-26-2009, 08:33 PM
Rockrunner86's Avatar
Rockrunner86
Rockrunner86 is offline
Originally Posted by PigDiesel9
Your right, there is no engine light, no pending or prior codes and all the monitors are running. Some vehicles dont throw codes right away. It could take extended driving to get a cel to come on.
I had this issue way back when our truck was mostly stock. My bet is its the exaust back pressure sensor or the tube is plugged. You can unplug the exaust back pressure valve at the turbo ped. to test. Its a two wire plug on the front of the turbo ped. down at the base..
  #29
Old 10-27-2009, 04:53 PM
Old and Busted
Thanks for the offer...I appreciate it. Missed this posting last night! Went to the dealer first thing...had a credit there anyway.
  #30
Old 10-27-2009, 05:21 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
I would keep the EBPS connected. If/when you get AE or a ScanGauge type thing, you can read your EBP to see how much of a restriction your exhaust system is (to include the exhaust housing on the turbo).
Quick Reply: 99 7.3L Turbo Diesel Power Loss and Hissing Sound
