Anybody using the Summit Dual Exhaust kit on a '93ish 5.0? - Ford Truck Enthusiasts Forums
Old 02-15-2009, 10:58 PM
DasCheckers's Avatar
DasCheckers DasCheckers is offline
DasCheckers has a good reputation on FTE.DasCheckers has a good reputation on FTE.
This one
Summit SUM-CBJJ118 - Summit® Dual Exhaust Systems - summitracing.com
I really need to buy an exhaust for my newly rebuilt motor so I thought this sounds like a great deal.
If you have it, did it bolt right in?
Also, how does it sound?
I'm trying to put it in my '93 F150 5.0 long box.
Thanks!
Old 02-19-2009, 04:36 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
They must have the wrong picture for that...that shows one of their generic "in front of the rear wheels" kits but the notes say it runs down the right side of the frame.
That whole listing is very confusing...because in the kit's contents it says it HAS that universal duals kit in it. I don't really understand.
From the description it just sounds like they stuck their headers with Walker's 2 1/4" header back kit and called it their kit, but now I'm not so sure.
Old 02-19-2009, 08:54 PM
I guess I'll just order it and find out!
It a combo of the following.
Dynomax Thrush Turbo Muffler http://store.summitracing.com/partde...part=WLK-17713
Dynomax Blackjack Painted Headers http://store.summitracing.com/partde...part=WLK-85054
Dynomax Universal Header Dual Exhaust Kit http://store.summitracing.com/partde...part=WLK-89000
Old 09-28-2009, 12:58 AM
sca91ford's Avatar
sca91ford sca91ford is offline
sca91ford is starting off with a positive reputation.
seems to be a great deal...
Looking to get the same kit for my 91 5.0, how did it work out for your truck?
Old 09-28-2009, 01:33 AM
97FRD1TN's Avatar
97FRD1TN 97FRD1TN is offline
97FRD1TN is starting off with a positive reputation.
my buddy put it on his 95 short box.It is junk and you have to cobble it on and does not sound very mean,i think he ran it a whole week and then scrapped it out
Old 10-01-2009, 11:52 PM
What he said, it sucks.
Took my Dad and I almost 3 hours to cut and weld one side.
Sounds ok, very quiet. Looks like ***, it's a cobbled together kit that is by no means a bolt in.
Sure, it comes with a few flexible pipes but you still have to pie-cut your *** off to get it around everything.
I need to call them and really give them an earful still.
I'm going to go with headers to single 2.5" now.
Old 10-02-2009, 11:37 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
That's what universal means. One size fits none
Your 2.5" single back will be sufficient. True duals that are two different lengths because they both have to run down the same side of the truck would seem to throw the balance off anyway because the back pressure will be different for each side.
I would go headers to a 2.5" Y pipe. 3" from the Y to a 3" inlet Muffler with dual 2.5" outlets and tailpipes. This will give you plenty of flow and both sides of the engine will be balanced.
Planning my Sixlitre tune, opinions appreciated Kcorrie 1987 - 1996 F150 & Larger F-Series Trucks 2 09-15-2014 02:43 PM
summit exhaust with dual tanks? Cduff 1987 - 1996 F150 & Larger F-Series Trucks 2 06-03-2014 01:09 PM
Correct Wheel Fitment. ScumbagSteve 1987 - 1996 F150 & Larger F-Series Trucks 6 01-28-2014 12:57 AM
460 dual exhaust headers ryanscott 1987 - 1996 F150 & Larger F-Series Trucks 23 07-03-2013 03:30 AM
Any one use the summit 4" exhaust system on their 7.3? wildstang 1999 - 2003 7.3L Power Stroke Diesel 22 11-26-2009 11:58 AM
Tags
1994, 4x4, dual, exhaust, f150, ford, kit, like, mufflers, racing, sound, sumcbjj118, summit, truck, wlk89000
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
