83 f150 dash pad replacement - Ford Truck Enthusiasts Forums
Old 02-15-2009, 09:19 PM
bernboy bernboy is offline
bernboy is starting off with a positive reputation.
how difficult will this be? do i need any soecial tools?
Old 02-15-2009, 09:24 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I have never done, but other people on here say it's easy, and it's about 12 phillips screws around the pad. Some people remove it to work on stuff behind the dash.
Old 02-15-2009, 09:37 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Exactly right, 12 philips screws is all that holds the dash pad on.
Three hold the instrument cluster bezel.
Two hold the radio bezel.
Three above the glove box door, under the lip of the dash pad.
Two in the left defroster vent opening.
Two in the right defroster vent opening.
Replacement Pads are still avaliable at Ford last time I checked. But they are only avaliable in Charcoal Grey.
The Dash Pads are swappable.
1980-1983: F-100
1980-1986: F-150/F-350
1980-1999: F-600/F-900
Old 02-16-2009, 07:43 AM
ccecilm2 ccecilm2 is offline
ccecilm2 is starting off with a positive reputation.
Very easy. Had it out on my 1984 a couple of times. If you have the chrome looking trim running across the middle just use a small screwdriver to pop out one end then just pull it out. It has several spring clips that hold it on.
Old 02-16-2009, 08:38 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1980/82 F100/350 & Bronco Padded Dashes
E1TZ1004282A0D .. Red / Obsolete *
E1TZ1004282A8T .. Nutmeg / Obsolete *
E1TZ1004282A5A .. Black / Obsolete *
E1TZ1004282A3U .. Fawn / Obsolete *
E2TZ1004282A3B .. Blue / Obsolete *
1983 F100/350 & Bronco Padded Dashes
E3TZ1004282B2A .. Black / Obsolete *
E3TZ1004282B1B .. Blue / Obsolete *
E3TZ1004282B1D .. Red / Obsolete *
E3TZ1004282B5U .. Tan / Obsolete *
E3TZ1004282B8K .. Teal / Obsolete *
E4TZ1004282B0P .. Charcoal / 149 are still available from Ford
MSRP: $520.27 // FTEpartsguy.com price: $374.59
* No Ford Dealer or obsolete parts vendor has any
Old 02-16-2009, 07:47 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
Quote:
It is very easy,but for those who are just removing yours to get at the wiring,be very careful cause most dash pads are fragile and will easily crack if not handled carefully.The sun and Dash pads do not get along at all.lol.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
1983, 82, dash, f100, f150, full, pad, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
