how are these tranny's holding up
Call Troyer Performance at 540-965-7126 for your valve body instead. He offers a superior product and the cost isn't stupid for what you get. Actually you can't find better for your money than what they sell. Tell them I referred you if you call.
But for a real fix for the overdrive issues there is more that needs to be done. The stock overdrive band is an issue all in itself and the overdrive servo has a tendency to leak around the servo pin. There are fixes available, but they involve more intensive transmission work.
Darrin
I had a retainer ring come out on my overdrive pack and cause it to lock up the over drive. I drove the truck for another 300 miles before i finally pulled the tranny out. Even drove it into my shop. It had 130k on it then. I bought a used tranny with 120k on it and now i have 190k on my truck with zero issues.
I tow some pretty heavy loads, including my boat to the ozarks. The 4r70w is a good transmission and if you are lucky enough to have the 4r100 then. Well ... Damn you....hahaha.
How many transmission pan bolts are there? My bet is 14 and that means a 4R70W. In that case definitely call Troyer.
But, if it does have the 4R100 then go with a factory tech kit because it's likely the best you will find for your money on that one. For God's sake don't call Troyer asking for factory tech though. LOL
Darrin
Darrin
