Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Ohio Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
  #1 (permalink)
Old 02-15-2009, 06:23 PM
jimm136 jimm136 is offline
Garage is empty, add now
jimm136 is starting off with a positive reputation.
89 ford f250 4x4
Need help with my truck . it started when i though i was out of gas (gage dont work ) put gas in it made it 2 more miles quit again put more in a bout 1/2 tank it quit 3 time in a mile. last time it ran. towed it home replaced fuel fillter new coil an cap and roter. it does the same thing it will start for a few seconds then it fires some then nothing. i can hear the pump working also i do have a hole in the filler tube that leaks. but i have driven it that way for months the codes i get are 15 24 67 51 24 67 some were always on. thanks jim
  #2 (permalink)
Old 02-15-2009, 08:42 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
I'd say distrutor module auto part stores can test this for you
  #3 (permalink)
Old 02-19-2009, 06:10 PM
i tryed again it started reved it to3000 up and down for 45 sec ?. stalled retried couple of times then fired then nonthing . sprayed starting fluid and it will stay running.
after the fillter it pump gas ?
Tags
250, 4x4, 67, 89, 89ford, dont, f250, ford, forum, gauges, specs, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
