Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-15-2009, 06:19 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
How much Methanol expected to recover?
After Distilling about a gallon of methanol out of a batch that started with 32 gallons of oil and 7.5 gallons of Methoxide, we went to drain bio from the processor to the wash tank. Had a very strong smell of methanol present, so back into the processor it goes. Manage to distill about a half gallon more out @ about 145-150 degrees. The Glycerol also has a very strong smell to it, and I thought that most of the methanol was in there. My question is, about how much methanol should be expected in each? What happens if methanol is introduced into the wash tank, or if gets into the engine?
thanks
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 02-15-2009, 06:42 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
There are quite a few variables in Methanol recovery. I recover about 45% of the total methanol I use ( I use 20%) on average. Sometimes more, sometimes less. Most of it is in the glycerol. I usually get about 20-30% from the glycerol, and 10-15% from the bio.
I usually make 10 fifty gallons batches at a time ( 50 gallons WVO/10 gallons of Methanol) and will recover about 4.5 gallons of Methanol from each batch.
Washing will remove most all the remaining Methanol out( either dry or water) Leaving excess methanol in the fuel is not good for your engine! It will absorb moisture, and can cause corrosion of the IP, and injectors........
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 02-15-2009, 07:38 PM
Rushmore X's Avatar
2003 Ford Excursion
So figuring 10-15% from the bio, 1.5 gallons fits right in there. That's comforting. We were a little concerned due to the strong methanol smell. Is the strong smell common? Should attach a picture of the bio, it turned out a slight honey color like the pics you've posted.
The weather's finally getting warm enough to do something, hope to get at least another batch going this week, hopefully 2.
thanks again.
__________________
  #4 (permalink)
Old 02-15-2009, 07:43 PM
1935 Ford pickup
Yes, the smell is common in unwashed bio. Be very careful of breathing Methanol fumes! Methanol is a neurotoxin, and even a small amount is dangerous to humans!
Sounds like you are comming along just fine!
__________________
  #5 (permalink)
Old 02-16-2009, 12:51 PM
Rushmore X's Avatar
2003 Ford Excursion
Quote:
yes, we are going to put one of those ventilation turbines in the roof, along with opening up windows...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
