2.3L Will Not Start ! - Page 2 - Ford Truck Enthusiasts Forums
Old 10-02-2013, 10:53 AM
Stinky1 Stinky1 is offline
Stinky1 is starting off with a positive reputation.
Two things here...many guys (not you) have a bear of a time getting the nut loose. When they put the thing back together they don't want to have that problem again so they don't worry about torquing it. They put it on to what seems tight and go from there. The key on the crank does not hold the pulley, it indexes it to the right spot and the nut, squeezes the "feeling" out of the pulley, so that it is too numb to move...thereby holding it into place, Therefore, if you don't torque the nut, in about 50K your pulley will wiggle on the crank and your pulley and maybe crank will be ruined.
#2...you can wrap a tie-down strap around the crank, then hook it on the frame and when the pulley turns it will tighten down and keep the pulley from turning while you crank on it.
1988 F259 w/ New 7.5 efi installed, will not start. EDsurvivor 1987 - 1996 F150 & Larger F-Series Trucks 16 09-08-2016 02:30 PM
REALLY! UGH, why me! res2cue Modular V10 (6.8l) 4 01-15-2015 09:15 PM
Trying to start a rewired 67 67F250RET 1967 - 1972 F-100 & Larger F-Series Trucks 9 02-01-2013 09:51 AM
1985 F250 EFI starting problems. WoodHeat 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 41 08-24-2012 09:34 PM
Need big time help with 89 2.3 Ranger dis 1987tc Ranger & B-Series 4 12-08-2002 12:45 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
02, 23l, 303354, crank, crankshaft, engine, ford, gauge, positioner, repair, sensor, specs, start, starting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
