Dome light lens removal - Ford Truck Enthusiasts Forums
Old 06-05-2002, 02:29 PM
fordman02 fordman02 is offline
fordman02 is starting off with a positive reputation.
I recently purchased red lights for the dome light of my 94 F-150 how do you get the lens off the light.
Thanks
Chris Gerstenecker
Old 06-05-2002, 07:07 PM
AlM's Avatar
AlM AlM is offline
AlM is starting off with a positive reputation.
Chris,
Our 96 Bronco's dome lens pops off with a slight squeeze on the long sides of the lens; it is the rectangular type. The Ford manual says" "To remove the lens, pry with a small screwdriver as shown:..."
and, "...To remove the bulbs, use a screwdriver or coin to push up and rotate counterclockwise 90. The bulb and bulb holder will then drop out from the lamp as shown:..."
hope this helps!
Old 06-06-2002, 07:22 PM
Drawsoncad420's Avatar
Drawsoncad420 Drawsoncad420 is offline
Drawsoncad420 is starting off with a positive reputation.
64 F250: Installing DC Headliner...How Does Dome Light Install? mikey1968 1961 - 1966 F-100 & Larger F-Series Trucks 8 11-25-2016 04:17 PM
WTB Dome Light Lens 1978 or Earlier Pinzer WTB - Parts & other 4 02-16-2016 06:25 PM
2015 dome light question BillME 1999 to 2016 Super Duty 0 06-08-2015 08:09 PM
Parts for our trucks that are still stocked by Ford? berry1234 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-03-2009 07:20 PM
1963 F100 Dome Light Mystery retroluxe 1961 - 1966 F-100 & Larger F-Series Trucks 10 12-30-2006 07:50 PM
Tags
94, aftermarket, bronco, cover, dome, domw, f150, f250, ford, interior, lens, light, lights, remove, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
