Transmission question
I'm asking this for a guy at work. He has a 2001 F-350 psd. his tranny just went out this week and the guy at the shop said that if you leave these diesel diesel in park at idle for extended periods of time it will burn up the tranny. he said you're supposed to put them in neutral not park if you're leaving it idle for a long time.
So the guy at work wants to know if thier is any truth to this becuase if its true than it took five years for it to ruin the transmission.
Also does a 2001 have an E4OD or a 4R100 becuase i want to know if this applies to my OBS PSD with the E4OD in it.
Thanks in advance.
Thanks in advance.
There is a vague amount of truth to it. There is more circulation when in nuetral than in park, but, the only advantage is if the transmission was really hot to begin with, pushing more fluid through the cooler will help it cool faster. But simply idling in park or N will not burn the trans up.
So what was said above and by the guy at the shop was wrong. if you've got that much experiance with AT then i am more inclined to believe you.
HicksTim
09-15-2010 06:47 PM
cowmilker08
37
04-12-2009 07:40 AM
dieselman19
03-08-2007 04:26 PM
macrac
19
02-24-2005 05:12 PM
