Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Computer Chips and Tuners SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-15-2009, 11:42 AM
dutchlincoln79 dutchlincoln79 is offline
dutchlincoln79 is starting off with a positive reputation.
'93 460EFI: what do i need to go sequential?
Hello,
i have a 460EFI from a '93 truck with a E4OD on it.
I have a baumannator unit for the E4od when needed.
Currently the engine is bank-fired, and speed-density.
Now, i would like to make it sequential, and speed-density or MAF, that's not a real point.
I can't see what i need due to the many possibilitys..
The engine/tranny is currently on a stand.
What do i need to make a sequential-setup?
naturally, i can throw a bucket of money and buy it all, but i rather fabricate it myself due the nature of the build.
Can anybody shine some light in the dark?
Thank you.
  #2 (permalink)
Old 02-15-2009, 01:31 PM
Conanski's Avatar
Conanski Conanski is online now
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
You need a MAF computer of course, you could try to find a california 460 computer which would take care of the tranny as well, and you'll need the matching engine harness to get the sequential injector, MAF meter, and extra O2 sensor harnesses. You could also use a mustang computer with a tuner and the Baumannator on the tranny, but you still need a complete engine harness or you'll have to add those extra wires yourself. Both methods have benefits, simplicity with the 460 computer, or performance tunability with the mustang computer, your choice.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 02-15-2009, 01:44 PM
well,
i'll probably will never run on gasoline, so i want to keep it as simple as possible.
All i need it for, is the propane injection in order to piggyback the system...
I have no troubles making my own harness, only thing is: where an i find the schematics?
My guess is that a cali-computer will do the trick, but what are the codes of it?
When i get a mustang (5.0?) computer, would it NEED to be reprogrammed?
I guess the mustang uses 19LB/H injectors, and the 460 uses 24LB/H, so when they're activated, the amount of fuel will automatically be more for the 460, as needed. I hoped that there wouldn't be any programming needed.
Oufcourse, when i need to install and fabricate the whole ceremony, i might just as well pull 2 fuel lines and use the sistem anyway when needed...
Any info/links?
Thanks!
  #4 (permalink)
Old 02-15-2009, 05:54 PM
Conanski's Avatar
1990 Ford F-150
There's a lot of info on fordfuelinjection including the computer pinouts on this page... Ford Fuel Injection. I can't find any boxcodes for 460 truck computers, they seem to hard to find. If you were to use a mustang computer it would need to be programmed with a chip/tuner, all the tables and scalars are way off so it would not be a simple plug and play operation.
__________________
Paul O
  #5 (permalink)
Old 10-25-2009, 04:07 AM
I intend to go for the mustang and a Quarterhorse.
Are there any suggestions about the computer code?
Since it's going to be a long-term project anyway, i may as well do it with with all the bells and whisles to make it as good as possible, and go for tunability instead of ease..
I know myself, if i go the "easy" way now, i'll pull it sooner or later anyway to make it the optimal way...
  #6 (permalink)
Old 10-25-2009, 10:52 AM
Conanski's Avatar
1990 Ford F-150
The Mustang A9L/A9P computers are the most popular and are supported by all these aftermarket tuning systems.
__________________
Paul O
Tags
460 , computer , conversion , e4od , maf , mustang
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
