Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 Performance Ford F-150's
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-08-2002, 10:32 AM
MAK347 is starting off with a positive reputation.
!!!!Spark Plug Ejection!!!!
Just a quick FYI. Re-tighten your spark plugs periodically! I blew the #3 plug traveling to Pa. on Thanksgiving day. The ejection force also severed the retaining ear on the coil pack and screwed up the threads on the cylinder head. Upon inspecting the spark plug, I found only slight imperfections on the last 2 threads leading me to believe that the plug slowly eeked its way out over time. I limped to a local Ford dealer who wouldn't honor the factory warranty due to the performance modifications I've made. I had a choice of replacing the head or removing both heads to install the heli-coils in all 8 spark plug holes for the same money - (3k ouch!). I opted for heli-coil fix for extra durability - I'm running 14psi of boost. I'm also writing a letter to Ford to complain as I've found out that this is a fairly common failure in stock and supercharged 5.4's. I've got 31k miles on my truck and will now check my plugs every 7-10k miles for piece of mind. Hope this saves someone else the wallet depleting aggravation I just experienced.
Mike K
2001 Black Lightning #3440
Diablo Chip - 6# Program
PSP Filter
PSP 6# Lower Pulley
Single Blade T-Body
Tranny Valve Body
Truck-Tracs Bars
Motorsport 1-1/4" Lowering Kit
Bald F1's
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-10-2002, 08:23 PM
Lightning2Fast is starting off with a positive reputation.
ya know thats bull that they didnt honor the warranty. im a ford tech..those plugs blow out all the time on the regular motors...the exoedition and f-series..it has nuthin to do with the mods.
Language edited by Moderator
__________________
94 lightning
ys trim vortech renegade
intercooled
detroit locker
ladder bars
42# injectors
level 10
2800 stall pi converotor
psp tuned
11.51 @ 117
501rwhp 647rwtq
STILL SPEED DENSITY
  #3 (permalink)
Old 01-02-2003, 05:58 PM
Tony1790's Avatar
Tony1790 is starting off with a positive reputation.
Come take a look on the Super Duty forum and the V10 forum, there is plenty of talk of the spark plugs blowing out on the # 3 and #4 cylinders. Sounds pretty common on the 5.4 and 6.8. Take them to small claims court to recoupe the 3k, it won't cost you much, no lawyer and Ford will more than likely settle before the court date.
Good luck
Tony in Alaska
  #4 (permalink)
Old 01-04-2003, 11:34 PM
jwasted is starting off with a positive reputation.
The 6 lb pulley is why the plug blew, you can say i am liar if you want. I have had 3 gen 2s so far . I have a 2002 at the moment, and it is modded heavily. Get some better aftermarket plugs and you will not have the problem anymore NGK TR6 plugs work fine for a cheaper set. They handle boost alot better than factory lol. Drop me a line if you want some other options on plugs.
  #5 (permalink)
Old 01-04-2003, 11:59 PM
Post !!!!Spark Plug Ejection!!!!
the pully change has little to do with the plug failure. it is a defect in the heads that ford is aware of. im sure the pully didnt help but the fact that it is common in the other vehicles says it all.
__________________
94 lightning
intercooled
detroit locker
ladder bars
42# injectors
level 10
psp tuned
11.51 @ 117
501rwhp 647rwtq
STILL SPEED DENSITY
  #6 (permalink)
Old 01-05-2003, 09:52 AM
I know of the problem with the heads, but look at the mods. When you upgrade to a deep sump oil pan you need more oil right ? same with pulleys and cold air inductions, for every upgrade there is another to even it out. When you put a 6lb pulley on it's time for new plugs, this is even more true considering the truck needs a chip and cold air with the pulley setup.
  #7 (permalink)
Old 01-06-2003, 11:17 AM
i agree...there is always a weak link...however there is no excuse for a plug to blow out of a cylinder head. if cylinder pressure was that high...the head gasket would blow or the bolts would stretch before a properly installed plug would blow out.
__________________
94 lightning
intercooled
detroit locker
ladder bars
42# injectors
level 10
psp tuned
11.51 @ 117
501rwhp 647rwtq
STILL SPEED DENSITY
  #8 (permalink)
Old 01-07-2003, 06:27 PM
lghtningstruk is starting off with a positive reputation.
  #9 (permalink)
Old 03-05-2006, 10:47 AM
Harley2003 is starting off with a positive reputation.
Smile Funny, FORD changed head design in 2003.
Isn't it funny that Ford decided to change the cylinder head design in 2003 for these motors!! One of the major changes they did was to improve the threaded area where the plug goes. Maybe it's because TOO MANY PEOPLE WERE HAVING THE SAME PROBLEM !!!!!!!
Frick me, when are these people (Ford Motor Co.) gonna realize that maybe, just maybe, they have a design flaw and they should help their customers get good service and satifaction from the maker of the vehicle. Thats BS because you run 6 PSI more boost that your spark plugs blow out !!! Give me a break. The spark plug can take it so why can't your cylinder head.
Why do you think consumer confidence is down when you ask them about their North American built car. It's not the quality of the vehicle, it's the crappy experience they get when they report a problem, especially if it is one of those "special, don't acknowledge we have a problem problems" How many times have you heard the service "A-hole" say something like this: "Oh sorry to hear you are having a problem Mr. Noosebalm, but we will get that in for a look ASAP, would you like to take advantage of our 29 point winter comprehensive inspection for $29.95?" My response is: "No Mr. A-hole, I would like to know why my spark plug flew out of my frickin cylinder head, perhaps I could log onto your internet and show you 1000+ websites pointing to this exact propblem, and then I could listen to you tell me how this is the first time you have ever seen this problem before"
I have been through this and read many blogs about a similar problem with the cams failing on the V8 SHO Taurus. FOMOCO tried to bury this deep in the political caverns within the company and many people have lost their motors with basically no course of action to get it fixed. IT IS A MAJOR DESIGN FLAW THAT YOU SOLD FOR FOUR YEARS RUNNING!!! I could go on forever about this but it all boils down to customer satisfaction. Something that seems to be disappearing rapidly in todays marketplace. Ifyou want to read more about this go to www.v8sho.com
If I sound a little bitter about this, it's because I am. I work in the "tool and mold industry" and I see the negative impact happening daily in my region of the world. It's time to learn a second language, perhaps Chinese would be a good choice? I will always buy a FORD product but as I get older I fear I might get wiser and possibly do something stupid. Chrysler seems to have built some exciting products lately. Come on FOMOCO make something to kick their butts. Something with 4 doors maybe. I'm pretty sure after many years in racing you could come up with something. Maybe an alternative fuel, all wheel drive DC motor torque monster. Just a thought.
Cheers,
  #10 (permalink)
Old 03-05-2006, 06:04 PM
bigsnag's Avatar
bigsnag is new and has a neutral reputation at this point.
It is totally a design flaw. Obviously it would be too costly to due a recall on them, but they should honor warranty's on these, even if there have been modifications. Even if Ford said, "yes we screwed up, they were poorly designed. We will repair the head with an insert for anyone who has this happen to them". I think everyone would be happy. Inserts are fine. In fact, they are probably better than even the new designed 8 thread heads.
__________________
2001 Ford Lightning
JLP built block, Patriot Stage 3 heads, JLP stage 3 cams, Kenne Bell blower, Kooks custom headers, Bassani catback, etc., etc. 619.8 RWHP.
1975 F150 Sold
built 460 with C6
  #11 (permalink)
Old 03-05-2006, 06:44 PM
Blurry94's Avatar
Blurry94 has a good reputation on FTE.Blurry94 has a good reputation on FTE.Blurry94 has a good reputation on FTE.
The newer style PI 5.4 heads have twice as many threads (8) as the old ones. Whatever you do, do NOT overtighten the plugs. This seems to be more common on the Lightings than the F-150's though. My guess is the there is more noise/vibrations and I'm sure that added cylinder pressure plays some part as well.
__________________
Matt C.
94 Lightning, blown/intercooled stock longblock, 1.76 60' 7.94 @ 90mph (1/8 mile)
01 F-150 4.6 2wd RC, K&N drop in, shorty headers, Flowmaster w/duals
  #12 (permalink)
Old 03-24-2006, 11:03 AM
mnalightning00 is starting off with a positive reputation.
is there a torque setting for installing spark plugs.
  #13 (permalink)
Old 03-27-2006, 08:46 AM
MustangGT221's Avatar
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Quote:
If you're a Ford Technician than you'd fully understand and realize that Ford would never honor a warranty of a modified vehicle. The only time they have to is when it is obviously not related - like the radio dies. Any other auto maker would have the same procedure.
They have every right to deny a warranty claim in this situation, even if it's related to the spark plug blow-out problem.
The real issue here is that there are millions upon millions of these heads out there that they'd have to replace if they issued a recall, and we all know what that would cost, it would sink Ford.
__________________
Justin-FTE Moderator
95' F-150 XLT 4x4, 351ci (393's out), 5 spd, 6" lift/35s
04' Explorer Limited 4.6L
94' Cobra - 28k mile cream puff
87-96 Forum
  #14 (permalink)
Old 03-27-2006, 11:15 PM
captchas's Avatar
captchas has a very good reputation on FTE.captchas has a very good reputation on FTE.captchas has a very good reputation on FTE.
dead wrong
Quote:
sorry man and i'm not flaming you .the mods have nothing to do with it.
there was a problem with the cylinder head design not the spark plug. the early heads did not have enough threads and would come loose.the late heads are fully threaded like 02 and newer.i forget the correct year 01 something month
all you can do on the early heads is retorqe them every 10 to 15k with a inch pound torqe wrench to proper amount.
the best plugs are motor craft or auto light.but here EACH to his her own
  #15 (permalink)
Old 03-29-2006, 10:02 AM
While there is a known problem with the spark plug hole in the heads...you can't say his mods had nothing to do with it. They obviously increased cylinder pressure and put more pressure on those plugs.
It may be that one was loose and finally shot out...or what...but you can't say it had "nothing" to do with it...it did...it probably just made it happen a lot sooner...
__________________
87-96 Forum
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
