Dealer cost to replace pinion seal
Old 02-13-2009, 07:24 PM
61 uni's Avatar
61 uni
61 uni is offline
I don't know why pinion seals go bad on dually's. I have put 2 in my 78 f350 and now my 02 is leaking. I just topped it off with oil. A quart was $20 with tax.
Old 02-13-2009, 07:29 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
My 01 is leaking too....
Old 02-13-2009, 07:34 PM
vettdvr's Avatar
vettdvr
vettdvr is offline
1) vent is plugged causing excessive pressure
2) Incorrect lubricant resulting in too much heat
3) Pinion bearing preload set too loose allowing shaft movement
4) drive shaft out of balance
5) U joints not correctly centered in the yokes
6) Over full
Old 02-13-2009, 07:57 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
I just did mine about 3 weeks ago with no leaks. One other reason that they will leak is because the pinion nut needs 470 ft/lbs torque to get things to fit together. I have the special socket that it takes to take the nut off the Dana 80. If you need to replace it again, you will need a torque multiplier to get the job done. Let me know if you do this yourself, I will send you the socket. . You will have to get the torque multiplier.
Old 02-13-2009, 08:09 PM
61 uni's Avatar
61 uni
61 uni is offline
Don't know how long it has been leaking, it's not bad, I just hate leaks. It took less than 1/2 quart to top it off.
Old 02-13-2009, 08:51 PM
beanhead6D5's Avatar
beanhead6D5
beanhead6D5 is offline
A 3/4" drive toqure wrench goes up to 600ft/lbs. if you can find one to barrow from someone and they have about a four foot handle,to make a easy pull.
Of course it my not fit under the truck to good.LOL
Old 02-13-2009, 10:58 PM
mueckster's Avatar
mueckster
mueckster is offline
That's where the torque multiplier comes in handy. You can use a 1/2" drive with a 4:1. Still a pretty good pull.
Old 02-13-2009, 11:02 PM
mueckster's Avatar
mueckster
Jim,
We may be having another PAA meeting at Rick's next weekend. Bring over your truck and we'll take care of that pesky seal, too. PM me or I'll give you a call tomorrow.
Old 02-14-2009, 08:24 AM
big poppa's Avatar
big poppa
big poppa is offline
Originally Posted by mueckster
Jim,
Guys, got quoted 450.00 for pass. side upper and lower ball joints, can i come over with a truck bed filled with beers, would that cover it, sorry for the hi-jack, just had too. Good luck on the seal bro...
Old 02-21-2009, 08:55 PM
61 uni's Avatar
61 uni
61 uni is offline
Got it fixed by a ford mechanic for $75.
Old 02-21-2009, 09:09 PM
megawatt00's Avatar
megawatt00
Was that at a dealership?
Old 02-21-2009, 09:12 PM
61 uni's Avatar
61 uni
61 uni is offline
No side job. I'd say he makes more $$$ at home than from his day job.
Old 02-21-2009, 09:42 PM
megawatt00's Avatar
megawatt00
I thought so. That's a good price! I'd pay someone $75 to do mine.
Old 02-21-2009, 11:33 PM
miller_feed
Jim, you don't have to pay anyone for this. We will do it for nothing, but beer. . But then again, you might be better off paying the 75.00 instead of supplying the beer here.
Old 02-21-2009, 11:52 PM
megawatt00's Avatar
megawatt00
Yea but replacing it there and drinking beer with you guys would be priceless!!
Excurvelle
03-28-2015 05:47 PM
Powerstoke73
08-16-2014 07:54 AM
stephen.south
02-28-2012 12:53 AM
ToolTime
1997-2006 Expedition & Navigator
04-23-2009 11:21 PM
zar
1999 to 2016 Super Duty
02-06-2007 06:30 PM
Quick Reply: Dealer cost to replace pinion seal
