anyone use 5w-40 synthetic
here since my last oil change a few weeks ago its been everything from 5* to in the high 50's, no problems what so ever, as I mentioned I'm planning on running it year round.
Keep in mind the only diff between a 5w40 and a 15w-40 is the oil weight when its cold, both have a 40 weight when they are at operating temps, there is nothing wrong with running 5w-40 year round instead of a 10 or 15w-40, you will probably notice easier(quicker) starts when its cold as well as a little quicker warm up times as I have, but as I mentioned, at op temps, its all the same.
Hope this helps man.
I highly doubt the 5W-30 is diesel rated. You can't put gasser oil in a diesel, but you can put diesel rated oil in a gasser. I'm thinking about putting 5W-40 in the wife's truck just so I only have to buy one type of oil. 5 gallon jug of Schaeffer 9000 will do one OC in both our trucks...
where you from in Oregon?
Same here on firing quicker, the only thing that is making the engine turnover faster was the addition of the DB high torque starter
