Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-13-2009, 05:37 PM
97biostroke's Avatar
97biostroke 97biostroke is offline
Garage is empty, add now
97biostroke is starting off with a positive reputation.
Safely heating Bio
Well you've all got me hooked on the idea of magnesol, so now its time to adjust the setup. Is it safe to heat up bio in our water heaters? I'm tryin to distill off the methanol. I know the boiling point is somethin like 137*F, just wondering how to heat it up to 150 or so without chancing a major explosion.
  #2 (permalink)
Old 02-13-2009, 06:35 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Yes it is safe, as long as the eliment is submerged. Just remember that after recovery you'll have to filter out the soap. Kinda like "snot"!
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 02-14-2009, 12:47 AM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
Quote:
So the soap won't settle out, huh? That isn't an issue with water washing, though, is it? Only a problem when you're dry-washing, right?
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #4 (permalink)
Old 02-14-2009, 10:44 AM
1935 Ford pickup
Quote:
The soap would settle out, but he's using an appleseed style of processor. Most waterheaters have a domed bottom that retains some liquid which you wouldn't want contaminated with soap.
__________________
  #5 (permalink)
Old 02-14-2009, 03:32 PM
Any simple way to heat it without using a water heater? We do the reaction in a 250 gallon poly tank.
  #6 (permalink)
Old 02-14-2009, 04:14 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
You won't be distilling any methanol off in a poly tote. I have a steel tank that I use designed after this system
GL's Eco-System state diagram
That after I drain the glyc I distill (around 175 degrees) most but not all the methanol off the BD. Then transfer into a 55 gallon drum that I circulate for a while then let the soap settle out then pump off the top into a 1 micron bag. This year I will be going from the settling tank to a Spinner II fuge for final filtering.
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 302K
AD's, IC, Rear Disc, OBA, Tuned by Tony Built by me!
Transmission by Racer X!
  #7 (permalink)
Old 02-14-2009, 05:31 PM
Lets say I make 120 gallon batch, using about 26 gallons of methanol. Am I looking at recovering a couple quarts or are we talking several gallons? And after the methanol is distilled off, I will be left with some soap and glycerine in the bottom of the fuel, right? Then its just a matter of separating that out and then on to the magnesol stage?
  #8 (permalink)
Old 02-14-2009, 05:36 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
I run an appleseed type of processor (water heater) and I use it to heat the bio to get the methonal off. trick don't let it set in there after you get the methanol off, keep it pumping and mixed until you get into an open tank. the little bit of soap left after that point won't hurt anything. I dry washed all last year using this method and no issues at all, the soap will settle out as soon as you stop moving it though so heat it and get the methanol off then immediately pump into your settling washing tank.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #9 (permalink)
Old 02-15-2009, 01:55 PM
tjbeggs's Avatar
Quote:
Most of the methanol is contained in the byproduct which needs to be drained off before distillation other wise you risk a reverse reaction. On a 120 gallon batch you might see a couple gallons of methanol out of the BD. If you use this method you may find Magnesol not needed or at the worst case you will find it easier (less needed, less time, less mixing) to use.
Like monsterbaby said with this method I don't use any washing. I haven't done any testing to quantify my fuel but with proper settling time (3 days) and final filtering I have clear and clean fuel with no water or soap (shake test with water).
__________________
Tim
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
