stering column shifter - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-13-2009, 05:01 PM
jayram75 jayram75 is offline
jayram75 is starting off with a positive reputation.
does anybody have a very loose steering column shifter ours on our 2000 expy 4wd is really loose and id like to fix it but wanted to see if anyone else had this prob i searched the site and saw nothing. Thanx
Old 02-13-2009, 05:37 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Under the dash at the bottom end of the shifter rod is a triangle shaped piece of metal that is held on by 2 torx bolts. I think they are a #25 torx size. It's up around the top of the column and is a bit hard to see but you can get to it fairly easily. Tighten those 2 bolts and the shifter will tighten right up for you.
Old 02-14-2009, 07:37 AM
thanx alloro ill give it a try later also have you done your tranny fluid yet ive heard horror stories about disturbing a working tranny. were going to florida from ny in april and im doing all fluids but am on the fence about the tranny fluid. thanx again
Old 02-14-2009, 09:34 AM
There's nothing wrong or harmful about changing the tranny fluid. I would just make sure it is done a week before you leave so that you have time to make sure there are no problems and that the fluid level is where its supposed to be.
Old 02-14-2009, 11:01 AM
thanx again alloro your advice was perfect i tightened the 2 bolts its just like new!! thanx again!
Old 02-15-2009, 06:32 PM
birchy birchy is offline
birchy is starting off with a positive reputation.
Excellent!! I was going to post this exact question a couple days ago but forgot... Thanks for saving me the trouble jayram75!
Old 02-15-2009, 08:50 PM
Ill tell ya this is the 2nd ford ive had with this prob but never bothered with the first but this being the wifes truck I had to fix it it was real easy i didnt have a t25 but a metric allen wrench worked nicely have a good one!! I love this site!!!!!!!!!!!!!!!!!!!!!!1
Old 02-15-2009, 10:05 PM
For future reference, what size allen wrench did you use?
Old 08-03-2009, 12:08 AM
Quote:
Alloro, I did try and do this back in February, but wasn't able to find the torx bolts.. it's bugging me again lately.
Do I have to take the steering column apart at all or am I just not looking in the right place?
Old 08-03-2009, 12:15 PM
No disassembly required. Here's a couple of pictures showing the plate and it's two torx bolts. I took these pictures laying on the driver's floor mat and looking up under the dash. Just to give you and idea of the angle of the camera, it was pointing from the floor heat ducts towards the drivers shoulder strap mount.
Old 08-03-2009, 01:41 PM
Great, thanks! (Last time I was pulling the steering column apart! haha)
Old 08-03-2009, 01:55 PM
lzrj lzrj is offline
lzrj is starting off with a positive reputation.
I too have that loose shifter. I also thought it was loose from inside the steering column so after taking it apart a few months ago, I found that there was nothing to tighten where the shifter connects into the column. Based on those photos Alloro provided, I will look at it again tonight.
Old 08-04-2009, 09:14 PM
mackben mackben is offline
mackben is starting off with a positive reputation.
will this also fix my 2001 f150 the shifter flops almost freely and now it will not engage in park? Any help would be great
Old 08-05-2009, 12:31 AM
The bolts under the dash were pretty tight. Still managed to tighten them a little more, but the shifter is still loose as can be.. based on lzrj's post.. I guess i'll leave it at that.
Old 08-05-2009, 11:14 AM
Quote:
Couldn't hurt to check, it only takes a couple of minutes.
F-150 94 column shifter broke. hjartland 1987 - 1996 F150 & Larger F-Series Trucks 12 02-22-2017 03:15 PM
Rubber shifter boot on column??? what gives 90turbo1 1999 to 2016 Super Duty 4 07-06-2014 02:49 AM
Loose shifter anybody? F250_JR 1999 - 2003 7.3L Power Stroke Diesel 3 05-06-2012 08:13 PM
Shifter Column issue? pizza guy 1999 to 2016 Super Duty 2 05-20-2011 11:03 AM
'78 E150 3-speed column shifter diagram airrj 1968-2013 Full Size Vans 2 01-28-2011 12:29 AM
Tags
01, bolt, bushing, column, explorer, f150, f250, ford, linkage, loose, problems, rod, shift, shifter, tighten, torx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
