You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
ONLY one question:
Acording to the written by Texas and with the diagram from BlueMule, I thought was the same , BUT are exactly the opposite ; Im confussed now: it can be done in either way, it doesnt matter, or what is the correct?
85 - 86 is the relay coil.
30 - 87 is the relay contacts.
ah, OK, thank you very much.
BTW, searching in the web, I found the module to use when you install a Third brake light. Here are the links, and one of my brake light.
UPDATE:
Well this weekend I put the relay and the third brake light worked fine. But after looking at the wire from the third brake light, I found that the wire had a little exposed part of the cooper material in the part between the camper shell and the tail door, so, now I understand why the third brake light shorted and blew the #13 fuse in the dash.
Now, my question is: do I let the relay there (with more connections, with the possibilty to fail)? or I reconnect the third brake light wire to the wire I found that comes on with the brake (only one direct connection)?
UPDATE:
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
