Lost my ignition key!
My friend has a 1986 F150 and he lost the ignition key for it. So, Im assuming he needs to get a new lock cylinder for it. The problem i9s, every instruction set I find requires you to turn the key to the run position to remove it, which I obviously cannot do. Is there another way?
It may not be the best, but the quickest easiest is to take a large screwdriver or chisel, and break the chrome piece off. It's not that hard to do. Then you can reach in there and release the pin, and take it out. The local parts stores have the new cylinder locks in stock. They will give you a new set of keys to go with it. Here's a link on how to do it.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
You have to use something pretty flat and reach in between the steering housing and lock cylinder. You should be able to find the button easily, there should be a hole on the outside of the column where the button is located. I have also used a good bit and drilled the button out before. You have to have very sharp bit to do this.
Obtuse1
17
01-25-2014 12:29 PM
JimJames99
07-15-2006 01:50 PM
