Normal idle vacuum-89 F250 5.8L
The truck is in my sig. I have installed a Comp Cams 35-255-5 camshaft and it has a KN FIPK and the air pump and associated plumbing is removed. I am wondering what kind of idle vacuum I should expect? It seems a bit low to me, around 16 in. hg. at idle and it wavers slightly with a corresponding speed change.
It is speed density EFI.
Thanks
Thanks
Doesn't sound bad to me, but you are probably getting close to the limits of the SD system at idle. If you think it's an issue, you might want to try an adjustable fuel pressure regulator and bump the pressure a couple of PSI.
Also, has the engine been rebuilt? An engine will gradually lose vacuum as the rings wear, so you might have to factor that into the mix.
