parking brake
parking brake
about a year ago i got new drums/shoes/adjuster. after that, the parking brake stopped setting correctly.
it would set if the front was pointed down the hill, but if the bed was pointed down the hill the truck would roll backwards about 5 feet before parking brake would engage.
i took it back to the shop that did the brake work and they said the rear cables were damaged and needed replaced. that didn't fix the problem.
another time i took it in and they said they adjusted cables. that didn't fix it either.
took it in again last week and they said the front cable was binding in the sleeve and not engaging the brake shoes fully. so they replaced the front cable and sleeve.
now the brake still is not setting correctly with nose uphill. to make it worse, it won't set pointed downhill either!
i am getting aggravated because i'd thought they would have diagnosed the entire system the first time and identified root cause. they say they have to rule out one thing at a time. seems to me like they are throwing parts at it and i have to pay for labor each time.
i am curious about your thoughts on:
1. what is going on with my parking brake?
2. is it common for a shop (this is a NAPA 4x4 center) to string repairs like this along in babysteps rather than find/fix the problem right off the bat?
i usually do repairs and maintenance myself, but thought i'd leave the braking system to the "experts". i am second guessing my thinking on that one...
And this all started after they did the rear brakes the 1st time? I think they screwed up the first time around and are now throwing parts at it because they don't know what they did wrong to begin with. I'd find another shop that can go back and fix the original problem with the brakes.
They charged you to adjust the cables? There is no adjustment, when they stretch the only thing you can do is replace them!
How do the brakes feel when stopping normally?
If the brakes are not adjusted up tight, the p-brake will not work very good or not at all especially if the cables are stretched, which they most likely are.
on
Sounds like the brakes are not adjust up right enough to start with. It is not normal for a shop of good quality to string along repairs let alone make the customer pay for stuff that doesn't fix the problem!! Our shop (Napa auto care center as well) if we screw up a diagnostic and it doesn't fix the problem we don't charge. It hurts but we can sleep at night......
mule- yes- the original issue that took me into the shop was grabby brakes when wet and an e-brake that took pushing the pedal all the way down to the floor to engage. but at least then it would engage. trouble started after that initial visit. i wish i had left well enough alone.
took it in for a fifth time today and they looked at it but couldn't figure it out. tomorrow they will take it in again and replace the shoes (at their cost). they said there are no leaks and the leading shoe is not placed in trailing position.
they said they realize in retrospect that all the charges may not have been totally appropriate. i have no high hopes about getting any money back, but at least they are committed to resolving the issue and are willing to absorb all costs from here on out. fwiw, i do trust that their intention is good. they are nice people and have been helpful on other issues.
any more ideas?
any more ideas?
today they made sure the drums were round and replaced the shoes and linings. only thing left that is not brand new is the parking brake pedal.
maybe it is the new shoes, but there was a LOT more rolling resistance as i drove it home today. had to get way into the accelerator pedal to keep my speed up. when i got home the wheels and drums were very hot and smelled (like hot brakes). is this something that is normal when the rear linings are new? does it take a while for them to seat, or did they adjust things too tight?
maybe it was because they were hot, but the brake grabbed much less than normal. instead of rolling back 5-10 feet- i would have rolled all the way back down my hill a quarter mile had i not stopped with the hydraulic brakes.
they have called other shops, ford, consulted the manuals and the almighty internet, and are still stumped on what could be causing the parking brake not to grab. everyone sure would appreciate it if someone had a silver bullet. anyone?
maybe i am expecting too much. is it normal to roll back several feet, or do your guy's brakes set without rolling backwards?
The path to hell is paved with good intentions.
vvv Your next post proves it! vvv
1. don't know what they are doing or
2. they are pounding sand up your butt.
GregonVI
10-29-2012 09:13 PM
dhglaser
13
04-16-2010 09:38 AM
Chas1234
04-27-2003 10:35 PM
