02 code p1121
P1121 indicates that the readings from the MAF and the TPS are illogical relative to each other.
Check for an air tube leak between the MAF and the throttle body. Check TPS and MAF connectors for obvious faults.
Beyond that, you'll need a good scan tool (easiest) or a multimeter to check several PIDs to properly diagnose.
Steve
Steve
ResJudicata
1997-2006 Expedition & Navigator
01-07-2016 09:52 AM
