Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-12-2009, 04:05 PM
iwanaflattie iwanaflattie is offline
iwanaflattie is starting off with a positive reputation.
looking for a flattie
hey guys you must know where is the best place to look for a good flattie
  #2 (permalink)
Old 02-12-2009, 08:49 PM
galaxie641 galaxie641 is offline
galaxie641 is gaining momentum as a positive member of FTE.
I've found you can buy a whole vehicle with a good engine in it a lot of times for the same amount a lone engine will go for if not cheaper. So don't limit yourself to just look for he engine also look for the vehicles they came in.
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'92 Grand Marquis
'97 F150 5.4L
'08 Bullitt #3947
  #3 (permalink)
Old 02-12-2009, 09:10 PM
Snowking's Avatar
Snowking Snowking is offline
Hail to the king baby
Snowking has a good reputation on FTE. Snowking has a good reputation on FTE.
I have one that should be good poteintial in a 1953 F250, but Im in Canada
__________________
2001 Ford F250/ V10 4x4 1969 Ford F100/ 300
1967 Ford F100/ 352 4spd 1957 Ford F250/ 292
1952 Ford F1/flathead 1950 Mercury M135
1949 Mercury M47 1947 Mercury half ton
  #4 (permalink)
Old 02-15-2009, 11:05 AM
petey shoes petey shoes is offline
petey shoes is starting off with a positive reputation.
don't know where you are, but, i have an 8rt in ny. what are you looking for?
__________________
42 1.5 ton marmon herrington all wheel drive
  #5 (permalink)
Old 02-16-2009, 01:15 AM
near barstow california...and i am lookin for a flat head six or eight
  #6 (permalink)
Old 02-17-2009, 10:08 PM
effie_man's Avatar
effie_man effie_man is offline
Fatty driving the Flatty!
effie_man is gaining momentum as a positive member of FTE.
i got 2 in the great white north (kinda near snowking)
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #7 (permalink)
Old 02-19-2009, 05:32 PM
an 8rt is a flat 8, it's just too heavy to carry to barstow!
__________________
  #8 (permalink)
Old 02-20-2009, 10:29 PM
Snowking's Avatar
Quote:
Eerie the similarites
(sorry)
__________________
  #9 (permalink)
Old 02-20-2009, 11:55 PM
effie_man's Avatar
"what an education, eh?" lol classic. Couldn't say it better myself.
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #10 (permalink)
Old 02-24-2009, 09:20 AM
texan2004's Avatar
texan2004 texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
You are ging to have to look in cooler climates. Most of the southern flat heads have the crack of death.
__________________
2003 F-250SD, 6.0 PSD
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #11 (permalink)
Old 02-24-2009, 10:55 AM
wat is the crack of death and do you mean to look for flatties in arizona and dry states like that
  #12 (permalink)
Old 02-24-2009, 11:28 AM
texan2004's Avatar
I'd look in Northern areas of the US or in Canada. The Achilles heal of a Flathead is the engine block. Most died when the developed a crack that runs from one of the valve seats to the cylinder. Back in the day, there were folks that could pin these cracks and sleeve the cylinder to repair them. The problem today is that the guys that knew how to do this are all dead or retired.
Initially, the engines ran fine. As they developed some age the cooling passages developed heavy scale. The scale served to insulate the block in places and the water in the block became less effective at carrying away the heat causing the block to crack. This is a somewhat simplified explanation. In any case, I have noticed over time that the good blocks all appear to be in the colder climates. My theory (and that all it is - my theory) is that over heating was a bigger problem in warmer cliamtes like where I am in Houston. Sadly, while the good blocks are all up north, the bodies up there disintigrated because of road salt. So what you have today is a guy in Arizona with a nice body and no engine and a guy in Illinois with a good engine and nothing to drop it into. A good place to look for a complete truck might be the high desert regions of the Northwest. Not as hot and little winter snow. If you just want an engine, any cold weather climate will do. Look at the responses you've gotten so far from folks that have good blocks - Canada - New York - Minnesota .....
Anything from a warmer climate that was wrecked with a good engine was gobbled up long ago. Think about the older vehicles you find in bone yards now. None of them appear to have ended up there becasue they were crashed. They ended up in the bone yard because they weren't running and were old and rusty. Someone wanted them off of the farm or out of the yard/garage. About half of them stopped running because the block cracked. Again, just my theory but I haven't seen much to dispell it.
Here is a good picture of the crack I tried to describe:
http://flatheaddrag.com/cracks.html
By the way, the article is a great go when you get around to tearing one down. Easy to read and very easy to follow. This guy ran into just about all of the common problems you can expect to encounter during the tear down.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #13 (permalink)
Old 02-24-2009, 11:55 AM
19fifty4 19fifty4 is offline
19fifty4 is gaining momentum as a positive member of FTE.
That is a great flathead site. Thanks for the link.
I'm not looking to hijack the thread but I have been looking for a flathead as well and have found one I will be checking out this weekend. I was hoping you guys could give me some tips on how to evaluate it. It is currently in a 50 F1 and runs. I'm buying just the motor but have the chance to hear it run before we pull it. The guy wants to rod the truck so he doesn't need the motor or 4 speed transmission. I get them both as a unit. It runs but I do not know its history. I don't think it has been rebuilt but if so it was a long time ago. My plan is to rebuild it and put it in my 54. How would you advise I check this out?
Many thanks,
Mike
__________________
mike
54 F100
01 F150
  #14 (permalink)
Old 02-24-2009, 12:04 PM
texan2004's Avatar
Look for water in the oil or oil in the coolant. Would be good if he let you pull the heads before you commit. If it runs for a while and does not overheat, you should be good. Even better if you can drive it.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #15 (permalink)
Old 02-24-2009, 12:21 PM
He has only had it a few months and I think he drove it just long enough to get it up on the trailer. No smoke or knocks but indicated the carb needed to be rebuilt. Said it was complete top to bottom and end to end. He'll fire it up and I can hear it run. If I like it we'll pull it and put it in the bed of my truck and I'll haul it back home (he's about 4 hours away).
Is there an advantage to having the whole thing as opposed to just a core?
__________________
mike
54 F100
01 F150
Tags
1952 , f6 , flat , ford , head , parts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
