Where is autolock module?
Old 02-12-2009, 02:09 PM
jenkins2's Avatar
jenkins2
jenkins2 is offline
Just traded in my 2000 4x4 Lariat for a 2004 model in supercrew. The old truck had the locking module mounted under the dash and I could read the locking combination off of it. However, the new trucks module is not in the same place. Can someone clue me in to where it is located, pls? Tks, Jim
Old 02-12-2009, 07:14 PM
shorebird's Avatar
shorebird
shorebird is offline
Behind the glovebox.
Old 02-12-2009, 09:34 PM
jenkins2's Avatar
jenkins2
jenkins2 is offline
Thank you, thank you, sir. Will check it out in the a.m. when I change the oil. Tks, again.. Jim
Old 02-14-2009, 01:23 PM
jenkins2's Avatar
jenkins2
jenkins2 is offline
OK. Have pulled the glove box but am unable to spot the module. As I understand it, the autolock combo should be on the module itself. Can see nothing that corresponds to that. What I am after is the combo, as it did not come with the used truck. Anyone out there that can lead me to the module? Jim
Old 02-14-2009, 09:39 PM
jenkins2's Avatar
jenkins2
jenkins2 is offline
Bump!! Anyone? Still have the glove box off. Jim
Old 02-16-2009, 01:12 AM
jenkins2's Avatar
jenkins2
jenkins2 is offline
Still unable to find the autolock module under the drivers dash or behind the glove box. Does someone out there know where it is located on a 2004 Lariat s/c 4x4????? Jim
Old 02-16-2009, 03:24 AM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
are you trying to get the 5-digit combo that works on the Drivers Door Keypad?
if so, the module is on the back wall of the cab behind the rear seats. do a search for methods to remove the seats to access that module and get the code that is printed on a sticker on it
Old 02-16-2009, 12:45 PM
jenkins2's Avatar
jenkins2
jenkins2 is offline
Tks, Tylus, will give that a shot. Jim
Old 02-16-2009, 05:06 PM
shorebird's Avatar
shorebird
Jenkins try here for seat removal instructions; https://www.ford-trucks.com/article/...2008_F150.html
Tylus thanks for getting me straightened out. It's the SD that has the module behind the glove box correct?
Old 02-16-2009, 05:40 PM
jenkins2's Avatar
jenkins2
jenkins2 is offline
Fantastic tutorial, Shorebird!!!! Just what I needed. Tks, again! Jim
JimsRebel
Ford Truck Parts for Sale
08-10-2014 02:06 PM
JimiDick
1999 to 2016 Super Duty
08-04-2014 01:28 PM
cujo8
07-28-2006 08:52 PM
jrisebo
23
03-27-2005 08:55 PM
Quick Reply: Where is autolock module?
