help fixing codes 328 (32) and 334 (34)
hi i ran the codes with a scanner and the shopkey program at school said those are also the two didget codes the scanner said code 328 is EGR (evp) voltage below closed limit and code 334 EGR (evp) voltage above closed limit. What are the probable cause is it the egr vacuem solenoid? or could it just be some vacuem lines? please help
thanks,
Jared
P.S.
is the search function messed up? when i searched it would always return no finds even when i search just "KOEO" i could not find any codes or anything though the search function
thanks,
Jared
P.S.
ceej4801
120
09-20-2016 07:51 PM
bigjd
01-18-2016 01:48 PM
Doc TeeRay
12-01-2015 01:36 PM
