How can I tell if my diesel engine is a powerstroke
I have a 1994 F-250 with a 7.3 liter diesel. It says turbo diesel on the fenders below the F-250 symbol, but does not say powerstroke. I need to find a rebuilt turbo for it as I am pretty sure the seals are blown due to the oil leakage and exxess usage. I am trying to determine if mine is a regular turbo or a powerstroke motor so I don't buy the wrong turbo. Can anyone help me out on how to tell the difference?
It's likely an IDI Turbo.
If it says "FORD TURBO" on the Engine cover it's an IDI Turbo (InDirect Injection)
If it says "Direct Injection Turbo" it's a PSD
You can go here and put in your VIN, the 8th digit tells you what engine you have:
If it's an "F" it's a Powerstroke, can't recall what the Turbo IDI engine letter is.
https://www.ford-trucks.com/vin-decoder/index.php
Well, the 8th letter of the VIN is an F, and the engine looks more like the image of the powerstroke picture than the others, but on the black cover in the center of the engine it has "diesel" on both sides and "direct injection" in the middle, but it does not have the word powerstroke. Can any of you point me in the direction of finding a rebuilt replacement turbo? I greatly appreciate the help!
Yours sounds like a powerstroke. The alternator will be on the opposite side than the pice. (The pic is a SD 7.3) If you fill oil in the VC it is a PSD. Direct injection is a powerstroke also.
There is a guy that does good turbo work on e-bay others will direct you to him.
To be honest it sounds like your o-rings between the pedestal and turbo are bad.
Check for play on the turbine wheel. That will tell you if you need a new turbo.
Not always is the turbo bad if it leaks.
Sounds like a Powerstroke, but to make sure look at the top inside (valley side) of the valve covers. If you have two (one front & one rear) electrical connections on the vavle cover gasket, then it's a PSD, if you see metal fuel lines and small injectors, then it's an IDI.
For your turbo on a PSD, check out ebay, there is a guy on there "Ron's Turbo Shop" that has good prices and does really good work. A bunch of people on here are running his turbos. I don't think he's listed under his name, so run a search for 7.3L turbos or powerstroke turbo and then look for him, make sure it's Ron's.
As stated above, make sure it's not just your o-rings leaking, cause they are cheap turbo's are not.
I am running a Ron Holland 1.00 A/R turbo. If you suspect your turbo, you might be dollars ahead to replace it. I had a bad oil leak in my intake tract and the engine was burning a lot of oil. I had no idea what was going on and a short time later when the bearings finally let go, I had a pile of junk on my hands. If the exhaust turbine contacts the housing, it is of no use as a core. That cost me $110 due to the damaged turbine.
On a lighter note, the 1.00 A/R was built using new components. Some of the holes in the housing (like the EBPV harness attachment) need to be tapped. It builds boost as low as 800 RPM. My stocker did not build until nearly 2000. It took my fuel economy from 9.9 to 12.68. I am hoping further mods will bring this number up further.
Replacement is not for the faint of heart or the inexperienced. It sukked.
Aaron
The link:
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
Aaron
The link:
[quote=Neal 97 250;7131993]Here is a powerstroke:
Attachment 13282
Do all the sooper's have two altenators or is that an ambulance package?
Attachment 13282
on
[quote=heathrunkles;7139480]
Nope dual alts is an option. Most just have one.
Attachment 13282
Attachment 13282
77_150_460
01-25-2010 06:14 PM
IDIDieselJohn
08-02-2009 09:34 PM
SeminoleSlim
25
07-15-2008 10:32 PM
